Eagle Air
Re: Eagle Air
What type of plane? What happened? When?
Re: Eagle Air
So close… yet so far considering the pilot should have made it to st andrews + reserves. Incredibly lucky they didn’t end up another statistic
Re: Eagle Air
That passenger sounds like a fun guy to have on board
Re: Eagle Air
The passengers up North are a different breed. They're unflappable. Whether it's cancellations, delays, or even the couple emergencies I've had, it's just another day at work.
Meanwhile you've got goofballs down here in jogging pants and sandals taking pictures of speed tape and losing their minds.
Be like Bryon... (But don't be like fricken Eagle Air!)
Re: Eagle Air
Seeing here full pax/bags limits the fuelweight allowed to be taken up for W&B legality, sometimes it’s going to be a lighter weight fuel drawn from underground warmth, as possibly here. It also can be at a max age and at a min octane cut for the grade … all combining to consume it slightly faster going into that colder weather trip, .. and maybe not as much tailwind as is flight planned
IMO it’s potentially that type of consumption rate issue that plays into this type of situation esp in this area of Canada at this time of year ( the repeating event being hinted in a previous post above )
Re: Eagle Air
Hmz... I find that highly unlikely. Usually in a navajo you set a fuel flow and get an airspeed. Even if that changes, you should have ample warning you're not going to make it to the field.
If you're referring to a change in fuel density, then that effect should be significantly less than a 30 minutes/45 minutes final reserve. It could be a factor , but a very minor one.
Did they fly CYAV - sachigo return, or was it a bigger trip?
The Hammer
Re: Eagle Air
Flew right by pickle, Red, Sioux look out, lac du bonnet too. All still have a gas....
Re: Eagle Air
Biggest safety devices in a Navajo
#1 jpi fuel totalizer
#2 gps
#3 ads-b
#2 gps
#3 ads-b
Re: Eagle Air
PDW taps away in a language that I too am not conversant in.
Re: Eagle Air
This guy is an absolute boss.
I've never been on a plane where that happens, but I know they can fly with only one. So everybody kind of took pictures and was joking about it
We stopped in front of a house and a little kid came out and started taking pictures, so it was kind of funny that way. We were joking, 'Hey, your bus is here,' and that kind of stuff
But honestly, it was kind of pretty cool," Cassie said. "You always think, in the back of your mind, I wonder what would happen if this happened or if that happened. And in this case, I got to live out one of these experiences with no repercussions. [It] was sort of like a bucket list thing for me.
Re: Eagle Air
At night???
Re: Eagle Air
Why not you’ve already done one illegal thing that day
- Rank Moderator
Re: Eagle Air
Really? What a load of bulls!t. Making the assumption that this is simply a case of not enough fuel, I can see your factors making 5, maybe 10% difference - certainly not enough to cover what should have been, at minimum, 30mins of reserve…pdw wrote: ↑Fri Nov 03, 2023 12:09 pm Seeing here full pax/bags limits the fuelweight allowed to be taken up for W&B legality, sometimes it’s going to be a lighter weight fuel drawn from underground warmth, as possibly here. It also can be at a max age and at a min octane cut for the grade … all combining to consume it slightly faster going into that colder weather trip, .. and maybe not as much tailwind as is flight planned
Happiness is V1 at Thompson!
Re: Eagle Air
Looked more like twilight, but you'd need to check what time they took off at.
Re: Eagle Air
Careful though, 10% of 5 hours is 30 minutes...North Shore wrote: ↑Sun Nov 05, 2023 1:11 pmReally? What a load of bulls!t. Making the assumption that this is simply a case of not enough fuel, I can see your factors making 5, maybe 10% difference - certainly not enough to cover what should have been, at minimum, 30mins of reserve…pdw wrote: ↑Fri Nov 03, 2023 12:09 pm Seeing here full pax/bags limits the fuelweight allowed to be taken up for W&B legality, sometimes it’s going to be a lighter weight fuel drawn from underground warmth, as possibly here. It also can be at a max age and at a min octane cut for the grade … all combining to consume it slightly faster going into that colder weather trip, .. and maybe not as much tailwind as is flight planned
Re: Eagle Air
Pickle and Sioux are quite a stretch off his track to make a low fuel diversion. I agree on Lac Du Bonnet or Red Lake but those would take some fuel awareness which I think was lacking at that point of the trip.The Hammer wrote: ↑Fri Nov 03, 2023 9:43 pm Flew right by pickle, Red, Sioux look out, lac du bonnet too. All still have a gas....
He did fly right by Selkirk on one engine, about 5 minutes after the other one quit from fuel exhaustion.
Re: Eagle Air
The three most useless things in aviation:
The runway behind you.
The air above you.
The geothermal heated fuel that you left behind in the underground storage tank.
The air above you.
atc_is_god
Re: Eagle Air
Stop making stupid fuel decisions that will kill your passengers and may land you in jail.
https://winnipeg.ctvnews.ca/pilot-avoid ... e-1.283887
Re: Eagle Air
Taking another look .. that may not have ended up too much better at that unfortunate point seeing the second engine approximately lost abeam to NW about 6miles out over the extended centreline of the nw/se Selkirk rwy when already pointing south into ‘SSW 10mph’ along the country road. How would it have been different if the forced approach got messed up trying to spot land it on that threshold of 3000ft, or not getting that far.
Re: Eagle Air
There’s two paved roads that run north south on either end of the Selkirk strip and several farm fields in the vicinity, plus even more mile roads in the same area, just look at google maps, it’s plentiful with forced landing areas.pdw wrote: ↑Mon Nov 06, 2023 2:51 pmTaking another look .. that may not have ended up too much better at that unfortunate point seeing the second engine approximately lost abeam to NW about 6miles out over the extended centreline of the nw/se Selkirk rwy when already pointing south into ‘SSW 10mph’ along the country road. How would it have been different if the forced approach got messed up trying to spot land it on that threshold of 3000ft, or not getting that far.
Even further, this pilot would have flown right past Selkirk on a direct track from Sachigo to YAV, he made a choice to try and cover up this mistake or the gauges were over reading, my money is on him hoping to make it to base and make up some bs to the passengers about why the engine quit, never ever filing a report.
But, I’m a pessimist!
