Difficulty in getting a RAIC?
FASAno809
Post by FASAno809 »
Hello,
I am currently in the 704 world now about to make the jump to the 705 world which requires a RAIC.
I do not have any convictions but my record is not clean as well. I had several charges in the past at different times but they all either ended with being withdrawn/stayed or I entered a conditional discharge and my record was wiped clean (none are drug/gang related). I have no problem passing a regular criminal check and crossing the boarders as I have been doing it for 704 operations consistently.
I know Transport Canada will see everything though as they request LERC (Law Enforcement Record Check) from RCMP. I was wondering what my chances are in getting a RAIC. My last charge was from 5 years ago. What can I do to increase my chances of getting the RAIC?
Anyone here that got their RAIC denied? What are you doing now? Did you appeal and did you try again to get a RAIC after the required 5 years wait time?
ElSee
Re: Difficulty in getting a RAIC?
Post by ElSee »
Bump - I’m in a very similar situation, did you ever receive your RAIC OP?
If an airline asks the question if you will be able to obtain a RAIC you have to say yes, you won't get hired if the answer is maybe or no. In your cases I would probably go get hired by Tim Hortons or EFC or Menzies or something and do the process. I don't know of a way to find out without actually applying for one, I know a guy who got let go before sim training when it turned out his pardon wasn't enough and he had more steps to go through. I don't know any specifics about his case except that as a young man he made some bad decisions.
TailwheelPilot
Post by TailwheelPilot »
How is anyone supposed to know if they will be issied a RAIC or not? Or is there a publicly accessible, very clear and exhaustive list of things that makes one unacceptable?
Bede
Post by Bede »
Ģenetally speaking, drug trafficking will disqualify you.
DUI you should be ok.
NotDirty!
Post by NotDirty! »
Bede wrote: ↑Fri Dec 01, 2023 5:15 am Ģenetally speaking, drug trafficking will disqualify you.
I’d prefer if you didn’t speak genitally!
The Barrel Man
Post by The Barrel Man »
For what it’s worth I have an assault charge and I’ve held a RAIC for almost 10 years. I’ve also travel to the USA a few times.
Thunder Bay radio, HEG is in the airborne section, call final for 27
mmm...bacon
Post by mmm...bacon »
The Barrel Man wrote: ↑Fri Dec 01, 2023 7:09 pm For what it’s worth I have an assault charge and I’ve held a RAIC for almost 10 years. I’ve also travel to the USA a few times.
Getting rowdy in the Winston! :lol:
FASAno809
Post by FASAno809 »
ElSee wrote: ↑Thu Nov 30, 2023 8:36 am Bump - I’m in a very similar situation, did you ever receive your RAIC OP?
Sorry for the late reply.
I did eventually get my RAIC even it took a year on the yellow pass.
My understanding having gone through the process is as long as you stayed out of trouble for the last 5 years and your past charges do not have anything to do with drugs/trafficking/violence, you should be fine.
I would start reading up relevant cases on CANLII.org as many has suggested here throughout the years here and have a letter/references/supporting docs ready to go if TC do ask.
Hope you do get your RAIC! Is a nerve racking experience for sure. Good Luck!
