Borek questions
2ndtime
Borek questions
Post by 2ndtime »
i have some questions about ken borek air, and here they are. i've heard about the rotations up north and i believe they're 3 weeks. what happens at the end of those 3 weeks? you get flown back down to calgary and then are you off for a couple weeks before going back up? how do they determine which pilots go to the south pole, the maldives, or any of the other locations? do you bid on them? and my last question is what type of flying is done out of calgary? charter, sched?
take it easy, and safe flying.
thx.
KAG
Post by KAG »
The northern rotations depend on where your based, and what type of plane you fly. They are either 2 week or 3 week rotations, and your flown from either YYC or YEG. During the spring, summer, and fall, when your off your rotation, you probibly wont be asked to work out of YYC. During the winter, you can count on it (if your a beech pilot). We do crew changes and charters out of YYC.
As for getting sent to Mali or the south poll, you have to be a DHC6 pilot.
who gets sent to either places, you just ask, but I'm not sure as I drive a beech.
cheers.
Chase lifestyle not metal.
just curious
Post by just curious »
Mali and Antarctica, aside from the obvious geographical diferences, are polar opposites in terms of selection. Generally new hire otter pilots are sent to the Maldives. This gives them a quick hit of Otter and float time (600 hours). After this they are free to ask for other bases. They also leave with a bit of cash since their expenses are low.
First officers for Antarctica have to ask, and generally often. Few first officers get to go down unless they are within a year of an upgrade. Almost no captains go down without a season or two as FO on the Ice. Money is better on the Ice, and there are few places (obviously) to spend it. Generally once someone goes down, they tend to be repeat visitors.
As for the Arctic bases, where you rotate to initially depends on what space is open. most jr pilots tend to be in the same base for a couple quarters before changing around.
JACKASS
Post by JACKASS »
Does Borek still hire the 500 hr pilot for F/O.
If so how do they upgrade some one with 250 hrs PIC to captian
TeeKay
Post by TeeKay »
King Air Guy-
So, is Borek looking for higher time King Air Drivers any time soon (nearly 3000 hrs in KA's and 1800 M/E PIC Turbine)? You guys are sounding better and better all the time.
