Fox Flight (EMT) was holding short of the runway, not the CAT 1 (they were the ones that took that critical video). As they crossed the glideslope bars, it causes a momentary instrumentation deviation for Endeavor.2112 wrote: ↑Tue Feb 25, 2025 7:07 amThe “Bump” ATC was referring to is regarding an aircraft holding short beyond the CAT 1 line for 23. I’ve seen this on the ILS 23 before, the glide slope buggers off for a few seconds above path while an aircraft is in the way of the antenna.pdw wrote: ↑Tue Feb 25, 2025 5:37 am Normally on a crosswind touchdown it’s not right at the point of a stall with a flat pitch. Therefore the right wheel here, although it seems like almost a “three point”, took on all of weight (W). The wing’s W (most of the left as well, and tail downforce) is all unloaded (exactly straight down) onto the one main in that split sec … so a ‘fresh breakage’ not impossible IMO , ie ‘fatigue’ evidence may be not available..,
Crew gets a warning about some kind of “bump” (possible ahead) … any PIC considers such ‘heads up’ warning. It’s seconds ahead of this event, so any reaction to that info is with-in the sequence of events of this accident as well.
Endeavor was on the visual at that point, and it's unlikely the glideslope bump had any real effect on the stable approach of the RJ. I'm sure the TSB will have a prelim report out that will show it was pilot error (mistakes happen). It was challenging conditions; snowy runway, gusts, crosswind. Poor landing technique led to an overload of the gear and wing spar.
Incredibly thankful no one died. It's in insurances hands now. The PIC and SIC are going to have to lean pretty heavy on the union, but they'll likely be released and unhireable at the 121 level.
