Fireboss Crash Offshore St. John's
Orion's Fannypack
Post by Orion's Fannypack »
Aircraft departed YYT for the Azores. I'm hearing it was an Air Tractor AT-802, 120nm east of St. John's. Pontoon located with debris, life raft found empty.
Edit...confirmed, Fireboss.
https://ntv.ca/life-raft-and-small-debr ... foundland/
Scary stuff...
MX-5
Re: Fireboss Crash Offshore St. John's
Post by MX-5 »
Holy crap, that has to be 1500nm
Taxivasion
Post by Taxivasion »
They have the capability to use the hopper as a fuel tank as well. lots of range!
AV80R
Post by AV80R »
How was the temperature at the time? Is it possible it was caused by airframe icing?
Passing you in my Tesla
Rooster69
Post by Rooster69 »
AV80R wrote: ↑Wed Apr 30, 2025 10:10 pm How was the temperature at the time? Is it possible it was caused by airframe icing?
It could be caused by any number of things. Why are you even speculating?
AV80R
Post by AV80R »
It's interesting for me to investigate possible cause.
Rooster69
Post by Rooster69 »
Speculating is not investigating.
Throwing out one possible cause, which can never be affirmed nor debunked, does not constitute investigating.
AV80R
Post by AV80R »
I enjoy speculating then.
Dry Guy
Post by Dry Guy »
The weather in St. John's the morning of the crash was around 0 degrees Celsius. Freezing precip may have been occurring over the North Atlantic.
‘Bob’
Post by ‘Bob’ »
Rooster69 wrote: ↑Thu May 01, 2025 8:35 am Speculating is not investigating.
A lot of investigating is literally speculating. The TSB has released reports with exactly what you are describing.
You really think that they will be able to deductively figure out the cause of the accident with no CVR or wreckage or witnesses?
If they found the life raft empty it likely means the pilot survived long enough to deploy it. Possibly too injured to get into the raft.
Can a fireboss handle rough water? Would it be possible to land on the ocean without severe damage after an engine failure?
Dry Guy
Post by Dry Guy »
AV80R
Post by AV80R »
I think it was more likely CFIT now. I wonder what the big hurry was to head into 1/4 mile drizzle and fog with 100 foot ceilings in a VFR aircraft with no rad alt. Saving Israel from fires?
