Jet stream down
Old fella
Re: Jet stream down
Post by Old fella »
Nauclerus wrote: Fri Mar 13, 2026 7:35 pm From the report ...
"The captain was hired by Northwestern Air Lease on 01 December 2022. He obtained his type rating on the Jetstream series 3200 on 22 December 2022. In addition to his Jetstream series 3200 type rating, the captain also held ratings on the Jetstream 3100, Convair 580, Lockheed L-188 Electra, Lockheed L-1011 TriStar, Canadair Regional Jet, and Boeing 737-600, -700, and -800 series aircraft. The captain also held a flight engineer licence with ratings on the Douglas DC-8, the Lockheed L-188 Electra, and the Lockheed L-1011 TriStar."
Odd career progression. Sounds like maybe they started off as an AME/Flight Engineer then progressed to a pilot position. DC-8 and L-1011 sounds like Worldways ? Typed on the B737-600/700/800 sounds like Westjet ? How did they end up in a crappy Jetsteam job flying in the north in the winter after all that ? Has this person's name ever been released in the media yet ? Why the secrecy !?
Somebody posted here he was “ old school type” who started his career before the mid ‘80s , well that is 40-45 yrs ago. Would certainly put him in the mid 60s yrs of age.
I think many can read between the lines on this sad crash.
‘Bob’
Re: Jet stream down
Post by ‘Bob’ »
As shortages of experienced pilots takes hold (it’s not going away because it is systemic), a lot of pilots like these are coming out of the woodwork.
They “tick the boxes” for regulatory or experience levels (ATPL, TT, MPIC, etc) but their actual experience is dated, not current, irrelevant, or incomplete.
And they often have the inevitable cognitive decline that comes with age, the inability to be taught and effectively retain new information, and the authority to steepen the cockpit gradient which has been inoculated out of most of Gen X and subsequent generations through an entire career emphasis on CRM.
What I’d like to know and probably never will is what he based the speed he needed to be on? Has any dry snow in -20 conditions ever survived an 80 knot call and look out the window in anyone’s experience?
Also a Type IV spray is awful on a medium turboprop and generally produces a “what the @#$!” reaction to the uninitiated. If the plane is performing better than that, I know it’s clean enough to fly.
phillyfan
Re: Jet stream down
Post by phillyfan »
Was there not a young kid upfront too? Was he just a passenger?
Pratt X 3
Re: Jet stream down
Post by Pratt X 3 »
Pardon my very limited bush experience, but is it considered normal ops to fly fast after take-off to blow any residual snow off the wings? Wouldn't the ability to get off the ground mean that the wings are providing enough lift at lower speeds so you managed to cheat death? Swept-wing jets can get squirrly just after lift-off with a contaminated wing (see CRJ/Challenger icing accidents) so extra speed can sometimes save the day but if you are taking the chance that the snow will blow off on the take-off roll, you'd probably want to make sure it did before getting airborne.
Have Pratts - Will Travel
Re: Jet stream down
Pratt X 3 wrote: Sat Mar 14, 2026 11:32 am Pardon my very limited bush experience, but is it considered normal ops to fly fast after take-off to blow any residual snow off the wings? Wouldn't the ability to get off the ground mean that the wings are providing enough lift at lower speeds so you managed to cheat death? Swept-wing jets can get squirrly just after lift-off with a contaminated wing (see CRJ/Challenger icing accidents) so extra speed can sometimes save the day but if you are taking the chance that the snow will blow off on the take-off roll, you'd probably want to make sure it did before getting airborne.
Not really for this particular situation, but it's very common and quite above board to fly a bit faster before raising the gear to make sure the snow you accumulated on taxi blows off and doesn't freeze the brakes on certain King Air models.
Even if you have deiced with certian home made procedures, I wouldn't fault someone for rotating at a bit of a higher speed assuming there's enough runway available. That's perhaps more of a grey area.
I am curious if the PIC really wanted to fly faster to blow the snow off the wings, or if it was to have a bigger stall safety margin due to a fear of ice sticking to some parts of the wing. The latter would make more sense logically, but that would once again be more important at rotation than when you actually make it airborne.
It might be a case of copying a procedure applicable to another type without fully understanding it (snow on gear) and then applying it to a different situation where it doesn't make much sense.
Re: Jet stream down
A couple of guys tried it in a 748 almost 20 years ago while everyone else was de-icing. Heard they were recorded talking about snow blowing off during the roll. Didn't work out so well.
Justjohn
Location: Just over the horizon ... & headed the wrong way.
Re: Jet stream down
Post by Justjohn »
‘Bob’ wrote: Sat Mar 14, 2026 10:38 am As shortages of experienced pilots takes hold (it’s not going away because it is systemic), a lot of pilots like these are coming out of the woodwork.
Hey Bob, who the heck are you and yes, stronger language IS implied.
The captain in question spent most of his career in the Middle East. Nearing age 65 COVID happened. His retirement wasn’t yet set up. As I’m sure you’re aware you can’t skipper a 705 airplane engaged in international travel beyond 65. This was his softer landing after COVID.
May we all equally be judged by either our finest or worst moments but you sir are taking one accident report and a whole lot of speculation and spinning a a yarn about someone YOU don’t know.
Be humble
Flying is better than walking. Walking is better than running. Running is better than crawling. All of these however, are better than extraction by a Med-Evac, even if this is technically a form of flying.
Dias
Re: Jet stream down
Post by Dias »
No, you're right. It makes zero sense. In a blackhole situation it's extra nonsensical.
cncpc
Re: Jet stream down
Post by cncpc »
Justjohn wrote: Sat Mar 14, 2026 2:51 pm
Be humble
Well said, John.
goingnowherefast
Re: Jet stream down
Post by goingnowherefast »
The plane might get airborne, but unable to climb out of ground effect. Lots of icing crashes are into the trees off the end of the runway. Fond-du-Lac and Dryden immediately come to mind.
If it doesn't blow off by blowing on it, then spray it off. What speed does the breath come out of one's mouth, 10kt? It'll be gone by power set, and definitely Vr
Dias
Re: Jet stream down
Post by Dias »
Repost
cncpc
Re: Jet stream down
Post by cncpc »
digits_ wrote: Sat Mar 14, 2026 12:27 pm
This. For sure.
This accident did not happen in a vacuum. If there is an inquest, these facts will come out.
NWAL was on its last legs financially. The ownership did not have the in house capacity to create a business plan that recognized the need for fleet replacement and would be capable of attracting investment to finance that. It was run by a pilot and pilot engineer. Their perspective was rooted in the past, their only management decision was to cannibalize their own operational fleet down to four aircraft. Their only strength was they had a monopoly on their routes. They had spent 8 years under the spell of some blow in, with no knowledge of aviation whatsoever, and a fantastical story of his own prowess in business. This accident was inevitable, with multiple causal chains possible.
The causal chain here traces back to the lack of financial ability to finance even repairs to the deice truck.
Within two hours of the accident I received a text from a friend in Smith. "They've finally crashed. All dead". I called her to find out what she was talking about. I found out, and was shocked, although I had predicted that event. She did tell me one thing. She said she had been outside at 6:30 that morning and it was snowing. The snow was in big flakes and wet on touching the skin, she said. Even at 20 below, that can happen in an inversion if the bottom cold layer is not deep. Our friend PDW has said there was an inversion at that time.
Diavik was a major revenue source for the company. The captain would have known that. I expect that in the tactile test, he determined that he would have some ice on the wings, not just on the leading edges. The normal solution to that, the deice truck, was not available. To cancel the crew change, for a reason tracing back to financial incapacity to ensure a proper result for a predictable safety challenge, might have lost the contract.
So the quote from Digits is spot on. That makes more sense. But that decision was not necessarily fatal. The decision to pair the captain and first officer was. It manifested in the lad calling the hung gear, and then directing the captain to slow down. Neither of those things would have been in his training or in any SOP. It is an example of his belief that he knew more than the captain, and of his marginal abilities as a first officer. Those were known to flight ops. Flight ops expected them to work out their incompatibility themselves. That beggars belief.
In fairness, it is not certain that the captain did reduce power. There is no verbal on that, and the statement that he did seems to be based on a couple of prop speed flickers.
Re: Jet stream down
cncpc wrote: Mon Mar 16, 2026 12:07 am It manifested in the lad calling the hung gear, and then directing the captain to slow down. Neither of those things would have been in his training or in any SOP.
Does NWAL not have a 'gear up and locked' or similar call in their SOPs when the gear cycle is complete?
cdnavater
Re: Jet stream down
Post by cdnavater »
digits_ wrote: Mon Mar 16, 2026 6:19 am
I don’t know of anywhere that has a call for that, typically in my experience and multiple types it called out when it’s checked with the after take off check. That is usually done after the flaps are retracted, which is usually done after 1000’ and accelerating to enroute climb.
Re: Jet stream down
cncpc wrote: Mon Mar 16, 2026 12:07 am The decision to pair the captain and first officer was. It manifested in the lad calling the hung gear, and then directing the captain to slow down. Neither of those things would have been in his training or in any SOP. It is an example of his belief that he knew more than the captain, and of his marginal abilities as a first officer. Those were known to flight ops. Flight ops expected them to work out their incompatibility themselves. That beggars belief.
Haven't read the report yet(too busy reading other non-aviation(mostly boring reports - and some cool winter activities).
Is it possible that the F/O suggested slowing down to avoid exceeding the maximum gear speed? That would seem to be a good callout, depending on how it was done.
Re: Jet stream down
pelmet wrote: Tue Mar 17, 2026 2:06 am
That's exactly what happened
cncpc
Re: Jet stream down
Post by cncpc »
cncpc
Re: Jet stream down
Post by cncpc »
cncpc wrote: Tue Mar 17, 2026 3:23 pm
The CBC report has quotes from the accident investigator.
Warkentin described the landing gear's failure to retract as a "benign" issue, but said it did serve to distract the pilots from the loss of altitude.
“You can fly that airplane around all day with the landing gear extended. Provided you respect the limits the aircraft manufacturer has set out in which to do that,” he said.
“It's more the timing of when this flight crew tried to fix that issue that resulted in them being distracted by the landing gear, likely focusing on the airspeed because they knew they needed to slow the airplane down. And then they just missed that 100 foot loss – and that's all it was – 100 foot loss of altitude and they hit the trees.”
Warkentin also said the snow from the aircraft could’ve been removed before takeoff with something “as simple as a broom” or a leaf blower.
"The snow wasn't sticking to the aircraft. So the key thing was to remove it prior to attempting to take off,” he said. “And that's what didn't happen.”
pdw
Re: Jet stream down
Post by pdw »
I get it …Maybe not SO much the “benign issue” if here must raise nose/AOA to reduce airspeed (flying 101) for the lower gear-up speed (gear issue) BUT here clearly were likely still worried (from report) about blowing off some snow (and wasn’t it still snowing?) … so maybe therefore hesitation to raise nose (respect of stall AOA?). A power decrease (flying 101) is for descending, yet here already at a shallow climbrate to keep higher snow-blowoff speed (caught between two limitations!)
SpyPilot
Re: Jet stream down
Post by SpyPilot »
A few clicks tell me the Jetstream 3212 Vlo and Vle gear speeds are both 160 KIAS.
What I couldn't find was the manufactures recommended minimum or maximum snow-blow off speed. :rolleyes:
airway
Re: Jet stream down
Post by airway »
cncpc wrote: Sat Mar 21, 2026 6:25 pm
That statement is odd. If the snow wasn't sticking to the aircraft, there is no need to remove it prior to takeoff unless the captain thought there was an unusual issue regarding the snow blowing off prior to rotation, which doesn't appear to be a factor in this case.
Re: Jet stream down
airway wrote: Thu Apr 30, 2026 10:15 am If the snow wasn't sticking to the aircraft, there is no need to remove it prior to takeoff unless the captain thought there was an unusual issue regarding the snow blowing off prior to rotation, which doesn't appear to be a factor in this case.
Say what now? :?
Dry Guy
Re: Jet stream down
Post by Dry Guy »
I've had to reject takeoff before because non-sticking snow didn't have enough time to completely blow off. Only the top layer blows off first and if the snow is thick enough the takeoff run won't be enough time for it to all blow off.
Re: Jet stream down
Dry Guy wrote: Thu Apr 30, 2026 11:25 am I've had to reject takeoff before because non-sticking snow didn't have enough time to completely blow off. Only the top layer blows off first and if the snow is thick enough the takeoff run won't be enough time for it to all blow off.
Yes, exactly. Or certain parts of the airframe heat up on the ground once engines are running, melting and then immediately refreezing some snow could happen as well. Not necessarily in critical amounts, but certainly a good reason to remove that 'non-sticking' snow...
airway
Re: Jet stream down
Post by airway »
digits_ wrote: Thu Apr 30, 2026 11:38 am
Yes, all of this can happen, and you need to be aware of it, but it doesn't appear to be a factor in this accident.
"An aircraft take-off performance analysis completed by the TSB laboratory indicated that the occurrence aircraft’s flight performance was not significantly degraded by negative aerodynamic factors related to critical surface contamination. Critical surface contamination therefore did not contribute to the aircraft’s collision with the trees."
It is legal to take off with snow on your wings that you are sure will blow off before rotation. If you think there is any possibility it won't all blow off, get it removed.
