WestJet strikes wingtip in YHZ
Autoland is an option off any ILS however the tolerances are only guaranteed under CAT II or III.According to Clint23's posting above, the incident occurred on RWY 14 in YHZ, which is a CAT 1 ILS runway, therefore, AUTOLAND not an option (it has to be a CAT 2 or CAT 3 runway for autoland).
onelargefoot
Agreed PIKA. I guess I was referring to specifically the YHZ wx conditions at the time. In that case, AUTOLAND was not an option.
EDIT: I'd add the following to my above comments after checking the relevant FOM. "Autoland is AUTHORIZED for CAT 2 or CAT 3 ILS facilities. Cat 1 ILS signal may not be satisfactory. "
So from your post PIKA, you say AUTOLAND is an option off of any ILS. That would be true I suppose if you want to do something NOT authorized by the FOM. In that case, you're SOL I should think were something to transpire that leaves you explaining yourself in front of the Chief Pilot etc.
So my take would be, that CAT 1 ILS AUTOLAND is not an option. Regardless of wx conditions.
I don't have access to your FOM but as I originally stated an autoland is available from any ILS. MAY NOT BE SATISFACTORY does not mean you cannot do it; it means you have to monitor the whole thing pretty close. Would you rather be in front of the CP explaining why you completed a successful autoland or why you scraped a wingtip? Your FOM quote does not explicitly state that you cannot do an autoland from a CAT I ILS.Agreed PIKA. I guess I was referring to specifically the YHZ wx conditions at the time. In that case, AUTOLAND was not an option.
onelargefoot
The comment about unsatisfactory signal from a Cat 1 ILS is meant to give background as to why an AUTOLAND is unacceptable. It does not open up the possibility of actually doing an AUTOLAND.Your FOM quote does not explicitly state that you cannot do an autoland from a CAT I ILS.
The more appropriate line to highlight is:
Doing an AUTOLAND under any other condition is a liability that no professional pilot would open himself/herself to. IMHO.Autoland is AUTHORIZED for CAT 2 or CAT 3 ILS facilities
AS for your statement:
well, I wasn't aware those were my choices.Would you rather be in front of the CP explaining why you completed a successful autoland or why you scraped a wingtip?
No professional would carry out an "Unauthorized" AUTOLAND thinking it the better choice versus a manual landing in low vis conditions. If the low vis manual landing was considered not safe given the conditions, then the only prudent choice would be a divert to an alternate. I would clearly like to state that this is in no way a reference to any actual event that may have happened. Your reference to scraping a wingtip is yours alone. I'm responding to AUTOLAND conditions period.
By the way PIKA, do you fly Transport Category jets? Just curious...
As I stated I don't have access to your FOM so I can't discuss what it says or does not.
My original statement that an autoland is available off any category ILS is valid. I have no interest in how your FOM further refines that statement.
Can you quote something from your FOM which says an autoland from a CAT I ILS is not authorized?
onelargefoot
So are you saying you would elect to do a cat 1 ILS autoland IMC? How do you know the signal is protected from other aircraft and vehicles, or that you have an alternate power source? Autolands are only done to Cat 1 signals, on Cat 2 runways under VMC for WestJet's FOM.737Driver wrote:The NG is capable of doing autolands on a Cat 1 ILS.
Why?? Do you have something to hide? The WJ FOM like everyone else's has to be approved by TC and becomes part of your operating licence. It's already in the public domain.leftyxl wrote:I don't think that describing the contents of our fom on a public forum is a good idea. Use a little discretion here eh?
onelargefoot
You're right on the money however Boeing doesn't say you can't do an NG CAT 1 autoland but only adds the cautionary note that excursions could occur in high traffic areas. Many companies have now taken the precaution of disallowing the use of NG CAT 1 IMC autolands because of this possibility. WJ in conjunction with TC has also taken this approach and it's now part of the WJ operating license and as such CAT 1 IMC autoland is not authorized under the WJ FOM..
To get back to the original topic since the crew were not authorized to use the autoland system under the WJ FOM they didn’t use it, although it must have been tempting....
onelargefoot
Thanks for the info Rebel. I see as well that someone started a thread under the Tech section of PPrune, on this very matter. Similar comments to yours are posted there.
BTW, for those interested, SunWing's FOM (737-800) has the same restrictions I mentioned above, and the same verbiage in their FOM.
I don't think it would be tempting at all to use Autoland on a CAT 1 runway. The procedures and calls during an Autoland are different from a Cat 1 ILS, and the confusion that would result is enough to keep the average joe from even contemplating it.
Although maybe the SouthWest guys at Midway or the Air France 340 at YYZ might have preferred Autoland, on a "2nd" try...
I said the airplane was capable, not sure how you read into it that I would do it. Now, I might be mistaken ( but I doubt itWJ700 wrote:So are you saying you would elect to do a cat 1 ILS autoland IMC? How do you know the signal is protected from other aircraft and vehicles, or that you have an alternate power source? Autolands are only done to Cat 1 signals, on Cat 2 runways under VMC for WestJet's FOM.737Driver wrote:The NG is capable of doing autolands on a Cat 1 ILS.
onelargefoot
like when you're playing "I bet I can chop your hands off" with a flight attendant and losing, only to then learn your first officer had earlier lost as well.an autoland was your only option
Addendum: A little cheeky humour...seriously though, if you think of all of the hydraulic and electrical and engine malfunctions that make a second autopilot not available, the odds of even having the aircraft knowing its supposed to do an AUTOLAND (by engaging the 2nd autopilot) are remoter still (following some sort of calamity).
