Is VV limiting when choosing an alternate?
grimey
Post by grimey »
lilfssister wrote: If the ceiling is 1000 feet or more but the visibilty is reduced to 3 miles or less by precipitation, smoke, or fog, it is still IMC/IFR.
If the ceiling is 900 feet or less and the visibility is 4 miles or more, it is still IMC/IFR.
Less than 3 miles, and 3 miles or more.
lilfssister
Post by lilfssister »
You are correct sir! I have corrected my post. Another good reason not to post, chat, watch a hockey game, and talk to the person beside you at the same time! :oops:
split s
Post by split s »
Anyone remember approx what year the metar was first introduced?
Hey bubbles,get me some of those dressed all over chips!
squawk 7600
Post by squawk 7600 »
It does make sense that a VV condition would be considered a ceiling as the value of the VV does determine a limit...so therefore treat it as a ceiling. I just wasn't sure if it was a limiting factor in determining an alternate because it doesn't state this fact clearly anywhere. A good place to put it would be in the CAP GEN I would think....same place where they make mention of TEMPO and PROB. Might help out alot of people.
On the other hand, there is one problem I do have with the VV phenomenon in the fact it is not as restricting as an OVC or BKN condition. Like I said before, you can most often see throught it at 005 when it is reported at 003 so how much reliablity does the TAF really have? Plus in a VV condition when related to FOG or SN, these conditions change rapidly and the TAF might not hold true for these reasons. I'd sure hate to scrap a flight because I can't hold my alternate based on a VV because of some SN condition.
zzjayca
Post by zzjayca »
split s wrote:Anyone remember approx what year the metar was first introduced?
I can't remember exactly but it was either 95 or 96 when we underwent our training for the conversion from the SA's.
Why doesen't Canada use ICAO units for measuring visibility in METAR's?
Every time I read a Canadian METAR ( which ain't very often ) I have to convert to get the picture for visibility.
Cat
split s
Post by split s »
[quote="zzjayca"][quote="split s"]Anyone remember approx what year the metar was first introduced?[/quote]
I can't remember exactly but it was either 95 or 96 when we underwent our training for the conversion from the SA's.[/quote]
Man time goes by fast, I guess it's been more than a couple years since vv did not count as a ceiling.
grimey
Post by grimey »
Cat Driver wrote:Why doesen't Canada use ICAO units for measuring visibility in METAR's?
Cat
Probably because we're right next to the US, and they don't either. I'm not saying it's a good reason, but...
swede
Post by swede »
I do not ever recall seeing V V in a TAF because it is striclty an observed phenomena, therefore it is not limiting because it is non existent in terms of flight planning.
" Probably because we're right next to the US, and they don't either. I'm not saying it's a good reason, but... "
Then why does Canada claim they use the ICAO format when they obviously do not?
I truly find your system to be difficult to understand, especially your CAR's.
Cat
chipmunk
Post by chipmunk »
swede wrote:I do not ever recall seeing V V in a TAF because it is striclty an observed phenomena, therefore it is not limiting because it is non existent in terms of flight planning.
Check out page 1 of this thread. :roll:
onezerotenthousand
Post by onezerotenthousand »
VV you'll USUALLY only see the under 300 feet so unless you going into a 2+ precision approach A/D it doesn't really matter, too low. Do you really want to make VV in the actual a safe alternate? Carry more gas if you can.
AND THAT'S THE WAY THE COOKIE CRUMBLES!
TeeKay
Post by TeeKay »
Swede -
Yep, VV is (part of a TAF, sure as BKN or OVC), and VV does, absolutely, just the same as OVC or BKN. Like Chipmunk wrote, see P. 1...
"An appeaser is one who feeds a crocodile - hoping it will eat him last."
-Sir Winston Churchill
grimey
Post by grimey »
squawk 7600 wrote: On the other hand, there is one problem I do have with the VV phenomenon in the fact it is not as restricting as an OVC or BKN condition. Like I said before, you can most often see throught it at 005 when it is reported at 003 so how much reliablity does the TAF really have?
This probably depends on how the observer is measuring the VV that the METAR and TAF are reporting and forcasting. If it's based off of a PIREP, you'll likely have ground contact at or near the stated VV. If it's based off of a balloon estimate, you could have ground contact at a significantly higher altitude, especially if there's any significant wind. Because the baloon rises at a fairly fixed rate, but gets blown around horizontally by the wind, the observer will end up measuring a vertical visibility by timing the balloon when they really observed a slant visibility. If there's a cloud base with little obstruction to vision below, it doesn't really matter much how far away the balloon is, so long as the observer still has it in sight when it enters cloud.
Note that I'm not advocating considering VV to be "better" than a similar overcast or broken ceiling, I'm just trying to explain why a pilot may see one as better than the other. With the METAR format, there's no real way to tell how the ceiling was measured. Assume the worst, and give a pirep if you see different on your way in or out.
Post by ahramin »
zzjayca wrote:I can't remember exactly but it was either 95 or 96 when we underwent our training for the conversion from the SA's.
I am sure it was before 96 so i'm guessing 95.
Big Bird Anonymous
Post by Big Bird Anonymous »
No one has answered the question yet.
If planning an IFR alternate and the TAF indicates a V V which shows a condition in which the vert vis is below alt. min's, is that limiting?
yes or no
Anti-antivaxxer
zaac
Post by zaac »
Yes
Alternate operating minima is decided by vis and ceiling.
VV is a ceiling.
TeeKay
Post by TeeKay »
Big Bird -
I answered the same thing as zaac back on Jan 8... and even before that on p. 1. Absolutely, it is treated as a ceiling, and it appears on TAF's all the time.
