King Air 100
- wait...what did he say?
King Air 100
I know theres lots out there... seem like a great plane. But what kind of stuff does a guy watch out for? I'm hitting the books here in the next bit, but I would like to hear some first hand advice...
You're Dangerous
It's alittle more roll sensitive than a 200, and if your slow and chop the power on landing you'll fall out of the sky. Flare at 110, and smoothly reduce the power and you'll greese it on.
other than the fact it's an under powered pig with responsive handling, what else would you like to know?
Cheers.
Cheers.
Chase lifestyle not metal.
If you are preparing for a PPC, be sure you are studying the correct airplane. There is a King Air 100, a King Air A100 and a King Air B100.
All slightly different.
Sort of like a Navajo 310, 325 C/R and Chieftain.
The King Air 100 was the first one. Originally with a 3 blade propeller and a 10,600 MTOW.
The A100 came next with a 4 blade propeller, improved fuel system, improved electrical system and higher gross weight.
The B100 is powered by Garrett TPE-331 engines.
With either the 100 or B100, know the current limiter test, it can be a bit intimidating. Other than that it is a pretty basic high performance turbine twin.
You will need a type rating for the A100 and the B100 but not for the early 100's.
IATRA?
IATRA?
- Rank Moderator
I can't quote the numbers, but it is due to the stall speed. It is higher than the max allowed. It runs along the same lines as the King Air 200. The straight 200 doesn't require one but the B200 does. This creates alot of greif with TC if you get a guy who won't issue the type rating.
The type rating is required if the airplane is a high performance and/or etc etc. The King Air 100 just squeezes under the requirements by a couple of knots. Vso I think. The A100 and B100, with the higher gross weight fits the definition. All King Air 200's require a type rating because of Vne. You are correct in that it gets confusing and TC does not always get it right. Some will issue a type rating regardless and others will check the books.
