clark headset-xmsns barely readable
red003
Post by red003 »
i've been having poor transmission strength/readablity with a david clark 10.13X in the air but not on the ground.
anyone ever have the same thing/know of a solution? i think it might be a ground wire and cust. svc is only open weekdays so i thought i'd try here before atc has a fit.
jimmyjazz
Post by jimmyjazz »
If you have a maintenance dept ask them for some contact cleaner,if not try some steel wool on the plugins.
JigglyBus
Post by JigglyBus »
I'd suspect the radio more than the headset.
Have you tried another headset? Or tried the headset in another plane?
Blakey
Post by Blakey »
Has anyone been playing with the microphone?
David Clarks have noise-cancelling microphones. No, not just the ANC headsets, that's a different thing all together. The microphone actually has 2 pick-ups. One on each side. It subtracts the engine noise and what not that it detects on the "outside" pick-up, from what it detects on the "mouth" side pick-up. Theoretically, this leaves just what you're saying without all the ambient cockpit noise. If it has been installed backwards, this could explain why it works on the ground when there is not much ambient noise.
Turn it around and try it.
red003
Post by red003 »
i'm pretty sure it's my headset b/c it's been in 2 different planes and each time it's been a problem i've used the handheld mic and been 5X5.
the d.clark troubleshooting page makes it look like it's probably a broken wire somewhere in the connector.
ScudRunner
Post by ScudRunner »
Does it sound like your talking through a tin can in the headset? Mine does that ocasionally. Im getting it checked out. Fortunetly i have a DC ANR one as backup :wink:
blaster
Post by blaster »
It is the mic. Get a replacement part... remove the 2 screws... change er up ... and bob's your uncle. I had the same problem a few years ago, been fine ever since.
Blakey
Post by Blakey »
red003,
If it is the mike you can get one pretty quickly from High-Tech Aviation in Markham. (905) 477-8032. Their prices are pretty average but they will take a credit card over the phone and ship it out via UPS the same day. You may need a model M-7/DC or a model M-7A. If you look really closely, it's printed on the sticker. The last one I bought was in the area of $135.
blaster
Post by blaster »
Before you go spending 135$, call the David Clark sales rep for the region or even their costomer services line. Tell them your problem and they may even send you the part for free. They did it for me. Apparently it is a common problem.
Good Luck.
Dockjock
Post by Dockjock »
Take off your ear seals and look at the rim of the ear cup on each side. There will be a date code for when your headset was manufactured. David Clark has a 7-yr warranty, no receipt required. Call them and get it serviced for free before you spend any money. I think you will have to pay the postage to get it there, but they will send it back for free.
Dockjock
Post by Dockjock »
Just checked, the date code is on the ear cup on the mic side. The date code is 4 digits mmyy. I've sent mine back twice and both times they not only fixed what I asked for, but also replaced the cord, ear seals, clips, and headpad. Awesome customer service.
oldncold
dc
Post by oldncold »
have an ancient dc and depending what type of aircraft you fly
and radio package the ohms of impedance can be different 8vs 4 as an eample which will cause some problems. the E' guys know this and check out what yours is and the imped's on the radio pack to see if they match if not and you fly alot in the bird. Then a new headset is in order that match
:idea:
cyyz
Post by cyyz »
blaster wrote:Before you go spending 135$, call the David Clark sales rep for the region or even their costomer services line. Tell them your problem and they may even send you the part for free. They did it for me. Apparently it is a common problem.
Good Luck.
/correct
jimmyjazz
Post by jimmyjazz »
yea call a rep before spending any doe I had a problem with my mike they checked the date it was 4 1/2 years old fixed it for free 1 year later brought it back with the same problem they said it was past warranty then noticed it had the same problem the year before so he goes to the counter grabs a new headset gives it to me and says DC's shouldnt break twice.
red003
Post by red003 »
i've narrowed it down to the mike. not a ground wire, which was my original thought. i tried twisting the boom around and the other side picks up fine in flight but the front is shot.
i asked the clark csr to just send me a new M7A mike but she said no b/c they'd have no way of verifying that my headset was less than 5 years old. so no go that way but it's going to kitchener aero when i get home from this gig.
thanks to everyone who's weighed in. nice to hear so many good reviews of d.clark warranty/svc.
Dockjock
Post by Dockjock »
(tap tap)
ahem,
Is this thing on?
Brint
Post by Brint »
I've been told by the folks at DC that the mics have a limited life. Once too much dust gets in there, it will start giving you problems. If you are missing the foam cover, it may speed up the problem.
wha happen
Post by wha happen »
i know a guy who rolled a plane over his DC's. Destroyed the headset, got a brand new one out of the box from the company. Now thats service
Its the way she goes boys, its the way she goes.
Lets sacrifice him to the crops.
oldtimer
Post by oldtimer »
I have a DC 10-13.4 and the mic takes a while to warm up. works fine after 15 or so minutes in a noisey airplane but longer in a quiet one. Another pilot has the same problem with the same headset. Maxcraft in YVR says $175.00 to fix it but that also includes new gell cell ear pads. ($35.00 in Aviation World)
overtorqued
Post by overtorqued »
hey oldtimer;
My 10.3 mic does the same thing. In the summer it transmits fine, however in the winter I usually have to yell "gear up".
