Why Pistons are better than Turbines...
DEDICATED TO ALL OF US WHO FLEW PISTON ENGINES
We gotta get rid of those turbines, they're ruining aviation and our hearing...
A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat.
Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start.
Cranking a piston engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a sexy girl friend.
On some planes, the pilots aren't even allowed to do it...
Turbines start by whining for a while, then give a lady-like poof and start whining a little louder.
Piston engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that.
It's a GUY thing...
When you start a piston engine, your mind is engaged and you can concentrate on the flight ahead. Starting a turbine is like flicking on a ceiling fan: Useful, but, hardly exciting.
When you have started his piston engines successfully your crew chief looks up at you like he'd let you kiss his girl too!
Turbines don't break or catch fire often enough, leading to aircrew boredom, complacency and inattention. A piston engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the
mind !
Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights.
Turbines smell like a Boy Scout camp full of Coleman Lamps.
Piston engines smell like God intended machines to smell.
It's a GUY thing...
mind !
- Cat Driver
Turbines and the "quiet, dark cockpit" give the bus drivers too much time to dick around with things best left alone. This gives rise to endless hours of wasted troubleshooting due to reports of counterrotating gimbal sprocket cage indications not normal etc.
I miss the gooey black stuff, it washed off easy, and didn't burn tender, unmentionable skin if you didn't wash it off well enough. (Skydrol anyone?)
If you don't know,ASK!
Flaps 1 Billion
Flaps 1 Billion.
Ah the myopia of youth
.... they will never experience the deep reasuring rumble of a big round engine, take pleasure in a clean hot start,
or know that your skill rather than some unfeeling computer will determine how well (or badly) the engine is running.
- Cat Driver
Not to mention the feeling of actually doing something with wrenches maintaining and fixing them...
But when one has never experienced things one can not compare..
Cat
Cat
I think F1B was referring to the state of your hearing after years of piston flying
- Amelia Earhart
- Amelia Earhart
Flaps 1 Billion
Re: Why Pistons are better than Turbines...
Fork-Tailed Devil
- Cat Driver
" Turbines - Cat Never say never- I use to think the same thing until one blew on me. "
My comment was toung in cheek, I have had two PT6 quit on me.
