I have a flight test on a 1900 and need help
ronnie up the road
Hey,
I got a ride on the 1900 "C" any questions I might be asked in the ground work you guys could forward will be greatly appreciated.
-Ron
-Ron
ronnie up the road
Re: I have a flight test on a 1900 and need help
Iam a mechanic that works on them, maybe help in that reguards. Systems, engines and stuffronnie up the road wrote:Hey,
-Ron
Use the search function.
Since I'm in a good mood, here you go:
http://www.avcanada.ca/forums2/viewtopi ... +1900+ride
Remember gravity and what a bitch she is...
"FLY THE AIRPLANE"!
http://www.youtube.com/hazatude
- skywatcher
Hello Ron,
How about these:
1)Know SOP's: rejected take-off, evcuatation procedures, other flight crew duties.
2)Performance limitations (you will be asked 3 or 4)
3)Starting procedures (hot start, hung start)
4)Emergency procedures (along with SOP calls)
5)System knowledge (general knowledge)
6)How to determine performance data (take-off distance, rate of climb)
From my experience, the ground work don't last too long. However depending on the examiner, they may get into some IFR knowledge as well.
Good Luck!!
How about these:
Good Luck!!
