anyone has any solid theory on 'why' or simple method on explaining?
many thanks!
That's probably the easiest way to understand it. Just make sure they know its dependent on A of A and not speed.The inside wing is on the inside of the "circle" and is therefore travelling slower through the air than the outside wing (the path it travels is shorter). Thus, it stalls first.
Here is where your explanation lacks logic... The leap from 'wing travelling slower' to 'wing stalling'... we're teaching that stalls result from high angles of attack, NOT from lack of airspeed.The inside wing is ...travelling slower through the air than the outside wing ....Thus, it stalls first.
soooo... You're saying thatNow just use the standard lift equation to compare the lift on both wings. All other things being equal (which they're not, but let's keep it simple) the 'V' squared makes the inside wing have less lift than the outside and stalls first.
I don't think thats exactly true Pam. After thinking about this for a bit and spending about 1 minute looking in a text book (because I'm tired and already have my licence, not because it was easy to find) I think that each plane is for sure producing a different amount of total lift, close to the same but not. The only one I'm really not sure about would be the one in slow flight, because it has so much drag its resultant of lift to drag will be a lot greater than the one cruising at 100mph. So slow flight aircraft I think might be producing the most lift, but again that is the only one I'm not quite sure about. Other than that aircraft A then C, and last but not least would be B. A,C, and B are all explained pretty well in Kersh*** but I didn't look hard enough to find slow flight aircraft. Anyone else care to explain what I can't?see, I always just like to say that the total lift of all those planes is the same
