l_reason wrote:TI-ANB
I do work alone when I’m up taking pictures. I do everything flying, mapping, dealing with ATC, and composing the shots with the camera in my hand. I set the camera fast enough so it can take a good clear picture every time. As it was stated earlier in the thread 1/800/s is fast enough most of the time.
Wow. Well, the only time I tried to take a picture while flying the plane I almost entered a spin
. Between keeping an eye on the plane and the traffic around me and composing the picture I noticed I was compromising my own safety. I'm a novice pilot (only 230hrs) and a novice photographer.... so for both tasks I gotta be very careful.
At the end, I decided to go up with other friends (pilots as well) so they can hold the plane while I'm focused on getting a good shot. The good thing is that I get to do two things I like a lot!
l_reason wrote:
I have used IS lenses in the past and found my self working with the stabilizer off most of the time because it makes little difference in the final images. As long as I can get a good clear shot every time I’d rather not have one more thing that’s going to complicate the camera, use battery and strain my arm.
Interesting! I don't have any IS lenses, but it is good to hear it from your experience. I did notice as well that you need high shutter speeds to get sharp pictures from the plane (well, it depends on the focal length as well... but we are talking mostly zooms I guess).
l_reason wrote:
Hand Jockey
A 20D is not the biggest, best or most complex camera I have used I had a Cannon EOS1Ds mark II for a week. I only used one feature and the only thing it did was make my arm more sore at the end of the day. I think your about right about how much will go in a 1G card. I do not want to be changing cards every 80 shots.. 250 is bad enough.
I friend of mine own one of those. It is way too expensive for me and in some cases it is not the best option. 5D sounds better to me (if you need Full Frame), but as you said... the 20D is a great camera, capable of taking very good shots.
Have you ever visited this forum? It has lots of good tips on Canon cameras:
http://photography-on-the.net/forum/index.php
Anyway...good choice on equipment and nice shots. Don't worry about people knowing about your camera/lenses, a good shot is the result of 50% skills, 40% knowledge and 10% equipment.
Leo
http://www.bluejaygallery.com
