Post horribly inaccurate forecasts here
master switch
master switch
If your gf is home then my chances are 30% PROBdesksgo wrote:CYHM 281029Z 281212 FM2300Z HAZ WILL GET LAID
"FLY THE AIRPLANE"!
http://www.youtube.com/hazatude
Captain S itmagnet
post horribly inaccurate forecasts here
Is this "horrible" enough to qualify?
New Orleans as Hurricane Katrina bears down on them.
KMSY 281753Z 07016G24KT 10SM SCT033 BKN200 32/23 A2968 RMK AO2 SLP052 T03170233 10328 20278 58012
KMSY 281720Z 281818 08020G25KT P6SM SCT030 BKN200
FM0300 02080G110KT 1/4SM +RA OVC003
KMSY 290353Z 04027G34KT 7SM -RA SCT019 OVC060 27/24 A2949 RMK AO2 PK WND 05038/0255 RAB0258 SLP991 P0002 T02670239
KMSY 290105Z 290124 05015G25KT 6SM -RA SCT020 BKN040
TEMPO 0206 VRB65KT 1SM +SHRA BKN010 OVC020CB
FM0700 04045G75KT 1SM +SHRA SCT005 OVC020CB
TEMPO 0913 VRB120KT 1/4SM +SHRA OVC010CB
FM1800 28045KT 6SM -RA SCT020 BKN050
TEMPO 1822 3SM -RA SCT030 BKN080
master switch
Just in case anyone is mistaken, cause i run into this often. FSS only do the observing, Enviroment Canada has Met forecasters who do the TAF's, GFA's etc. FSS have nothing to do with any forecasting. I love it when i get a phone call from a pilot after i changed the weather to tweak the TAF so they can legaly take of or land or whatever they are going to do. I try to explain that enviroment is responsible for those things. Then turn around and 2 days later he is phoning me asking me to change the TAF.....It's just banging your head against the wall sometimes.
FSS: puting the Service back in Flight Services....
- Speedbird Junior
Well actually, science is all about predicting the future. If it doesn't make a prediction, you can't even call it science; if it gets it wrong, well then it's bad science. But yes, they often can and do see the future.{...} but no one can see the future.
Those met guys are just useless eh?TEMPO 0913 VRB120KT 1/4SM +SHRA OVC010CB
Bad TAFs often arn't the fault of the met guys either. If a station is fairly isolated, and there arn't many stations around it, the TAF is going to be garbage a whole lot more than it will be if it has 10 other stations within 100NM to help with the forecast. They can only use the information they have available.
Masterswitch your hot can I flick you on!!
sorry could not resist !!!
By the way back on topic TAF's are not all that bad ! remenber the people who Analyze the weather , are just like you they don't know much more about it than you do! we as pilots have to take all available data and Analyze it our self.... use the GFA , TAF , surf progs, then you might just not agree with the TAF at all ,and realize that the weather is going to be alot worse than forcasted!!!
Most flying is a forward motion mine is doing backstrokes!!!
- Redneck_pilot86
SPECI CYPL 081845Z 27012KT 240V310 12SM -TSRA BKN045CB BKN260 RMK CB6CI2=
METAR CYPL 081900Z 27022G34KT 240V310 6SM -TSRA FEW010 BKN030CB BKN260 19/17 A2959 RERA RMK SF1CB6CI1 G48 PST HR SLP016=
TAF AMD CYPL 081854Z 081801 27012KT P6SM SCT020 OVC040 TEMPO 1820 3SM TSRA BR BKN020 OVC040CB
FM2000Z 27012KT P6SM SCT020 OVC040 TEMPO 2022 3SM -SHRA BR OVC020
Bit of a difference between 12 kts and 48kts
master switch
SPECI CY 261021Z 18003KT 1SM BR FEW002 FEW250 18/ RMK FG1SF1CI1 VIS NW 4=
SPECI CY 261044Z 21004KT 8SM FEW005 SCT100 19/ RMK SF1AC2=
METAR CY 261100Z 22003KT 8SM FEW005 FEW035 BKN085 20/19 A2991 RMK SF1SC2AC3 SLP127=
TAF CY 261147Z 261212 20005KT P6SM SCT120 TEMPO 1214 5SM BR
You should have seen the TAF last night. Was calling for 1/2 mile and VVof 200! Thought I was going to sleep in but alas no dice!
- Redneck_pilot86
master switch
master switch
lilfssister
- Rank Moderator
Sis...quit being racist against Germans
"FLY THE AIRPLANE"!
lilfssister
- Rank Moderator
