none
north of 50
none
Post by north of 50 »
message edited
alabaster
Post by alabaster »
never had any problems with fuel transfer except the last gallon or two but thats to be expected with the nature of the system. Also we have the baron stol and never noticed any ram air tube, as far as i know its strictly gravity feed.
north of 50
dhc-2 tip tanks
message edited
Have you asked your AMO?
north of 50
DHC-2 TIP TANKS
message edited
Crazed Windscreen
Post by Crazed Windscreen »
Sounds like a line problem from the tip to the front tank to me?
When was the last time the tip tanks were used and did you check the drains?
north of 50
dhc-2 tip tanks
message edited
twotter
Post by twotter »
As I mentioned in the maintenance section, check for a venting problem.
north of 50
dhc-2 tip tanks
message edited
