BEST Climb Rate
BEST Climb Rate
Yes i'm a jump pilot, and have a question for anyone out there..
When you are climbing to alt. and you have a full load of divers, what is better to get the BEST Climb Rate VSI?
1. Jumpers in the back of the plane (more weight in the tail)
2. Jumpers as forward as they can get?
And again this is when i'm in the climb NOT on the take off...
I would think it's jumpers in the back, In most planes a rearward c-of-g is more efficient than a forward one. This is because the horiz. stabilizor is usually rigged to provide a downforce, and by moving the c-of-g rearwards you reduce the amount of downforce it needs to provide, thereby reducing the total drag on the aircraft. I would think this is just as applicable (if not more so) in a climb as in straight and level.
TopperHarley
As long as you aren't exceeding MTOW and your within the CG envelop of the a/c, the position of the CG should really have no effect on your max climb rate.
The position of the CG will effect your stability and the way your elevator feels/responds. Comparing a forward CG and a relatively aft CG (again, assuming you're within the CG envelop), the forward CG will provide greater stability and the elevators will feel relatively heavier (more stability, less maneuvarability).
To achieve your max climb rate, you need to fly the proper AOA (or, as the POH will put it, IAS) for a given weight and density altitude.
"Never travel faster than your guardian angel can fly." - Mother Theresa
mellow_pilot
mellow_pilot
You'd have the least effective weight (and therefore the best climb) with the C of G right at the wings' center of pressure/center of lift. But.. it would have really bad longitudinal stability (it'd be pitchy.)
edit to add: and yes, in most planes you move the CG back to get closer to the C of P.
Re: BEST Climb Rate
I doubt it would make a big difference. Stability though is another story.imfsub12 wrote:Yes i'm a jump pilot, and have a question for anyone out there..
Timing is everything.
From my experience, if you don't have a turbo, above 10000-11000, once they turn around, if they stay in the back.. to get more confortable, place their booties, or whatever, it just stops climbing, get them forward. pretty soon.. just when they see you turning your head.. they'll understand. but they forget everytime is seems.
enjoy
enjoy
