another 777 engine failure
master switch
Post by master switch »
what is up with this?
NEW YORK
A jetliner carrying more than 250 people lost power in one of its two engines Wednesday but landed safely at a nearby airport, officials said.
The Boeing 777 plane landed at John F. Kennedy International Airport less than a half hour after the engine failed, said American Airlines spokesman Billy Sanez. Officials were investigating what caused the problem on Flight 134.
"The plane landed after the captain declared an emergency," Sanez said. "It's not a common incident, but the pilots are trained to deal with these situations."
The plane was en route to London from Los Angeles. Sanez said all the passengers would be put on another plane.
also this...
Date: 30 JAN 2001
Type: Boeing 777-31H
Flight 069 aborted its take-off run on runway 16 at low speed as a result of a failure within the left (No.1) engine. Although the failure was associated with a large compressor surge within the engine, no subsequent fire developed and the aircraft was able to safely return to the terminal building on its remaining serviceable engine. Failure of the Rolls Royce RB211 Trent 892 engine was a result of the release of a single blade from the low-pressure compressor (fan) rotor disk. The blade release caused extensive damage to the remainder of the fan and the intake shroud, however the event was fully contained. The only escape of debris from the engine was small, low energy fragments, causing minor damage to the fuselage and the opposite engine.
and this one..
DATE/SITE: 22 Nov. Paris - Rio de Janeiro
AIRCRAFT & REGN: 777-228ER of Air France. Flt: AF442
CIRCUMSTANCES: F-GSPE landed Fortaleeza Brazil after heavy vibration in #1
(GE90-90B).
DEATH & INJURY: Nil
PRELIMINARY ANALYSIS2 Imagery at http://www.iasa.com.au/081203.htm:
ETOPS 2.5hr transit (after 6hrs in cruise). Inlet guide vanes damaged.
and this one...
AIRLINE: Japan AL TYPE: Boeing 777- REGISTRATION: - C/N: - AGE: -
OPERATION: DSP FLIGHT No.: JL 1922 FROM: Naha TO: Tokyo-HND VIA: -
OCCUPANTS: PAX: 355 CREW: x
FATALITIES: PAX: 0 CREW: 0 OTHER: 1
INJURIES: PAX: 0 CREW: 0 OTHER: 0
DAMAGE TO AIRCRAFT: minor
12 minutes after take-off from Naha, the hydraulic quantity in engine #2 dropped to almost zero forcing the pilots to shut down the engine. Subsequently, a safe single engine landing at Naha was made.
and this one...
http://www.airliners.net/open.file/0263116/M/
seems to be the RR engines.
WRX
Post by WRX »
Heart Attack? :shock:
EyeOh
Post by EyeOh »
I'm no statistition. However, there seems to be quite a bit of time in between these failures. Also considering the number of 777s out there, that actually doesnt seem to be that bad is it?
twinpratts
Post by twinpratts »
A week ago, there was a Air India 777 that took off just before us in YYZ. 12 mins into it, they declared an emergency, got vectors & began to offload the gas. Not sure if it was a fire, failure, or precautionary shutdown.
2 cents, pls :lol: .
conehead
Air India 777
Post by conehead »
There's a bunch of United Airlines guys up from JFK right now in an Air Canada hangar to do the engine change.... Apparently United does an awful lot of the Maintenance for Air India...
C-GPFG
Post by C-GPFG »
On September 18 at approximately 0420 UTC, a Malaysian Airline Systems B-777-200, registration 9M-MRM, experienced a shutdown of the right engine while about 40 miles northwest of Brisbane, Queensland, in Australia. The engine was restarted and the airplane returned to Brisbane. The incident is being investigated by the Australian Transport Safety Bureau.
On March 11, 2005, American Airlines flight 908, a Boeing B777, N790AN, experienced a right engine fire and aborted the takeoff at about 110 knots at Ezeiza International Airport (EZE), Buenos Aires, Argentina. The 14 crew and 195 passengers performed an emergency evacuation. The incident is being investigated by the Junta de Investigaciones de Accidentes de Aviación Civil (JIAAC), Republic of Argentina.
PeteThePilot
Post by PeteThePilot »
I'll never fly again. :wink:
Clodhopper
Location: Wishing the only ice I saw was in my drinks...
Post by Clodhopper »
Clearly its a problem with the aircraft itself...
:roll:
a.k.a. "Big Foot"
TFE731
Post by TFE731 »
Clodhopper wrote:Clearly its a problem with the aircraft itself...
:roll:
You mean the engines. Don't forget that Boeing doesn't make the engine, Rolls Royce does. :idea:
Clodhopper
:roll:
Sorry...
[sarcasm]Clearly its a problem with the aircraft itself...[/sarcasm]
a.k.a. "Big Foot"
195psi
Post by 195psi »
There are options for either GE or RR engines.
There is an emergency AD out for the GE engines. Apparently there have been power rollbacks on takeoff when using reduced take-off thrust or generally setting the N1 and temp using the computer.
The FAA has ordered that all 777 with GE engines do takeoffs with max takeoff power.
The problem stems from a software glitch ans should be corrected with a software upgrade.
See the link for the AD.
http://www.airweb.faa.gov/Regulatory...D?OpenDocument
Spruce Moose
Post by Spruce Moose »
Is Air Canada's 777's going to have RR or GE engines?
EI-EIO
Post by EI-EIO »
Given GE's exclusivity on some 777 models and GECap's involvement in AC's bailout I'm guessing Trents :D :twisted:
Four1oh
Post by Four1oh »
another 777 engine related problem:
apparently some of the GE's had a thrust rollback during takeoff.
http://www.airweb.faa.gov/Regulatory_an ... -20-51.pdf
195psi
Post by 195psi »
Please read my post 3 posts ago. I alreday posted this info with the AD.
Four1oh
Post by Four1oh »
but there were no pictures! how could I read your post when you have no pictures!!?? :shock:
195psi
Post by 195psi »
Yes fair enough. I almost missed your reply but then the emoticon drew me in.
Four1oh
Post by Four1oh »
:D
master switch
Trent Flyer
Post by Trent Flyer »
Delta 777 diverted into YYT a few weeks back after having oil pressure problems (as in no oil pressure) with an engine. Word is they didn't shut it down to avoid ETOPS certification ramifications.
tica
B777-GE
Post by tica »
PIA in yyz in jan. had air turn becouse #1 eng.developed high vibes, fan blade tip protector disbounded.Damage:cold stream panels,several blades.three days in a hangar.GE engines.
