Wing tip vortices a la pushing tin...
Okay so this morning over a nice cup of mocachino I get talking to this guy and he has no idea what I do for a living. Conversation goes this way and that, and he starts recounting a story of one time he was in the Cook Islands back in the early nineties.
He claims that he and a friend had a condo right by the airport and they used to go sit next to the threshold and watch the 747 come and go every day on it's way to New Zeland with fruits and such.
So one day he claims the they got the bright idea after a few beverages to go stand on the threshold as the 47 takes off towards them. He claims that the end result is that they were lifted clean off their feet and thrown through the air like rag dolls.
Now he thinks he's had an encounter with jet blast, or that he's nearly been sucked into a jet engine and counts himself lucky. I try to explain the phenomenon known as wake turbulence which he has a hard time believing. Now his story seems plausible to me for some reason.
So first I ask him if he's ever seen the movie Pushing Tin with Billy Bob Thornton to which he says with a perfectly straight face, "no why?".
So I'm almost inclined to believe this guy and this leads me to my question:
Have any of you ever actually heard of this happening in real life?
Can anybody prove that it's actually happened by video or pictures?
CJ
CJ
http://video.google.com/videoplay?docid ... 8013139574
Hard to tell if he just put the camera down, or got thrown...
LMAO at the people on the beach!toolow_flaps wrote:check out these poor plane spotters.
http://video.google.com/videoplay?docid ... 3682552533
It does look like the camara underwent something violent in nature.grimey wrote:http://video.google.com/videoplay?docid ... 8013139574
Thos are funny videos!
I'm famous.
Grimey:
I took that video earlier this summer.
I was thrown about 40 feet or so, then got sand blasted from dust and what not.
If you look at my posting history you'll see it a few months back.
cheers.
Grimey:
cheers.
Semper Fidelis
Semper Fidelis
the clips demonstrate that this is certainly possible. I imagine from basic airmanship that the 'best' place to experience the effects of wake turbulence/wingtip vorteces is to be at the exact point of takoff along the runway ie when the main wheels are 1cm off the ground...you get the benefit of the wings having to carrying the entire weight of the aircraft and the proximity to the ground so there is no dispersion of the turbulence.
my two cents anyway
dc
my two cents anyway
dc
Nope. Induced drag (and wingtip vortices) are going to reduced when in ground effect, because of the reduced outward-spanwise flow of air underneath the wings.'best' place to experience the effects of wake turbulence/wingtip vorteces is ... when the main wheels are 1cm off the ground
I love accelerating in ground effect, both upright and inverted - it's great when you've got some AOA that you want to get rid of.
It's also another reason I love flying in close wingtip (line abreast) formation aerobatics - the induced drag of the inner wings of all aircraft is decreased at high AOA. Combined with the angular geometry effects, line abreast kicks ass compared to echelon. But again, any Transport Canada Inspector could have told you that.
Too much paper, not enough physics.
- Cat Driver
Many moons ago the tower in Vancouver let me hold at the yellow line about half way down 08 and watch the Concorde take off.
The concorde was in high alfa and almost airborne as it passed my position.
I was in a C150 and the turbulence was only strong enough to make the airplane shake a bit.
Cat
Cat
Vortices are a function of wing loading. Takeoff, there are no significant vortices until rotaion.endless wrote:I personally would think that it's jetblast doing all of what's been discribed. I can't believe that the vorticies would be strong enough.
Flying an approach heavy, slow, clean (or little flap vs more) will make significant vortices because of the wing load.
There's a video on YouTube about trying to blow a car off the runway. Maybe that's been linked here. I didn't check. Anyway, the result with less than TOGA is impressive.
I remember coming into ppl groundschool one day and just as i sat down the teacher was playing a video. Every class hed have some vid playing before it started. This one was of a frickin 172 or some small Cessna and you could actually see the vortices on take off. Has anyone else seen that? Back then I was way too shy to ask about it....but if anyone has a link to it, or knows what Im talking about that would be amazing. Id love to see it again.
- Cat Driver
The very best way to see wing tip vortices is looking back at your spray pattern as you pull up and start the turn on a calm morning when you are flying a Stearman spraying a tobacco field.
Re: Wing tip vortices a la pushing tin...
co-joe wrote: He claims that the end result is that they were lifted clean off their feet and thrown through the air like rag dolls.?
Thinking back at last's week take-off from London Gatwick behind a B767 (I fly an A310) and the way we were rocked when we flew through its wake, I have no problem imagining a 170-180 pound guy being seriously ''sucked off'' his feet like said...
Now, anyone brave enough to provide some actual unfactored video proof??? Well, not me!
Also, if you ever happen to be in YYZ on Carlingview drive when anything heavier than an A320 flies over you on approach to 24R, you might just catch a glimpse of the sound and effect of vortex.
OR, look at the water on approach to the 08's in YVR, and see the vortices settling onto the bay. You can see them on a humid morning too, on landing or takeoff. You'll often see the mist form on the wing as it loads up on rotation, or from the wingtips or the flap tips on approach in a high humidity day.Cat Driver wrote:The very best way to see wing tip vortices is looking back at your spray pattern as you pull up and start the turn on a calm morning when you are flying a Stearman spraying a tobacco field.
Chances are you can outclimb a heavy on departure, but you'll be on a similiar glide path on approach unless you specifically avoid the GS.
This is on the PSTAR and since they ask these questions on every TC test you will take.C-FART wrote:the clips demonstrate that this is certainly possible. I imagine from basic airmanship that the 'best' place to experience the effects of wake turbulence/wingtip vorteces is to be at the exact point of takoff along the runway ie when the main wheels are 1cm off the ground...you get the benefit of the wings having to carrying the entire weight of the aircraft and the proximity to the ground so there is no dispersion of the turbulence.
my two cents anyway
dc
Wake Turbulance is most pernounced when you are
Heavy: need to produce more lift to stay Airbourne
Slow: Need to increase you AoA (not going to discuss Newton)
Clean: Flaps help brake up the vorticies
Not in ground effect: The ground doesn't allow the vorticies to develope thus reducing induced drag
Hope this helps DC
Lurch
Take my love
Take my land
Take me where I cannot stand
I don't care
I'm still free
Take my land
I don't care
I'm still free
Well I was flying in a C-152 with an ex girlfriend during training and was behind the A320, I. mmm we was rocked pretty good, not to sure it was wake turbulence but I say it wasCat Driver wrote:
Cat
http://www.berkeley.edu/news/media/rele ... /wings.AVI http://www.coe.berkeley.edu/labnotes/01 ... lence.html
Okay gents what I was getting at was that the best REALISTIC place to be (standing on the ground...maybe with a camera filming it so we can all get a laugh) would be at or just after the point of take off.
Yes I know wingtip vortices are reduced while in ground effect...but I hope we aren't suggesting there is nothing at all going on directly between the wingtip and the ground (a distance of about 20 ft on a 747) when it is at 150kts and lifting into the air.
For a quick reference read (esp the part about vortices forming immediately on take off)
http://www.flywestwind.com/WTC/Pprograms/turbulance.htm
Lurch, thanks for the refresher on heavy, slow and clean. kind of remember it being on the PSTAR and perhaps ALL the other TC exams I have written.
BTW wingtip vortices are best produced from Delta wing type aircraft in the above configureation...might want to add that to your lecture notes. :p
I guess for 'optimal' effect one would have to find someone willing to fly a fully loaded concorde or maybe topped out 747 just over Vsi without flaps at an altitude equal to the wingspan of said aircraft. Good Luck!!!
Lurch wrote:This is on the PSTAR and since they ask these questions on every TC test you will take.C-FART wrote:the clips demonstrate that this is certainly possible. I imagine from basic airmanship that the 'best' place to experience the effects of wake turbulence/wingtip vorteces is to be at the exact point of takoff along the runway ie when the main wheels are 1cm off the ground...you get the benefit of the wings having to carrying the entire weight of the aircraft and the proximity to the ground so there is no dispersion of the turbulence.
my two cents anyway
dc
Hope this helps DC
Lurch
FG, I think they cover that in this article where they experiment with wing tip vorticies.
