Steep turns procedures
Agaim I'm getting ready for another group of PPC trainees and getting bored. So here goes.
So when you are teaching steep turns, all four different types of them do you
1. Do a HASEL check
2. Set the aircraft up in advance to a particular airspeed
3. Climb to a higher altitude
and if so why.
1. Do a HASEL check
and if so why.
I wish I could spell
1. No, I only have them do a HASEL before any maneuver with sudden altitude lost. Just do a 360 look-out
2. Yes, have the A/C stable and trimmed makes it easier for the student.
3. No, if 2000' AGL you're fine, you better not be losing more then 100'
I will add the limitations I put on my students. If any of the below are exceeded recover/return to normal flight
1. +/-10 kts
2. +/- 100'
3. + 10 degrees of bank
Explain if they exceed these limits they could be in a spiral and need to perform the proper recovery.
Lurch
1. +/-10 kts
2. +/- 100'
Lurch
Take my love
Take my land
Take me where I cannot stand
I don't care
I'm still free
Take my land
I don't care
I'm still free
Forgot to add 2000' AGL to start incase of a spiral or when they are solo. When they get good I drop them down to 500' better horizan and the ground throws them for a loop.
Take my love
Take my land
I don't care
I'm still free
Take my land
I don't care
I'm still free
- bob sacamano
Why would you do a 360 look out before a steep turn?
I'd have a look both ways, but to do a shallow turn that will take me longer just doesn't make any sense to me. Steep turn in itself can be your lookout.
From lesson #1, they should know what the steep range looks like.
I'd have them pick a bug on the windshield, and keep it on the horizon. I'd also cover all the instruments up as well, this way their head stays outside the cockpit.
Don't turn the A/C 360 degrees, turn your head 360 degrees, I said 360 look-out not turn check. Start at the back window at your side and go around until the back window on the other side.
Take my love
Take my land
I don't care
I'm still free
Take my land
I don't care
I'm still free
Justwannafly
Thats what I would say too...except I'm a bit stricter then Lurch....for someone who already knows how to do a Steep turn (aka PPC)Lurch wrote:1. No, I only have them do a HASEL before any maneuver with sudden altitude lost. Just do a 360 look-out
1. +/-10 kts
2. +/- 100'
Lurch
1. +/-10 kts
2. +/- 50'
3. + 5 degrees of bank
An experienced pilot should not be doing a manouver at limits...
Why?...cause someone may be flying behind you. I'magine following someone & all of a sudden they do a 180 right infront of youWhy would you do a 360 look out before a steep turn?
You don't have to fly a 360...just LOOK 360
PPC as in Pilot proficiency Check or PPL Private pilots Licence?
I use 100' as a recovery altitude I would like to see if they can regain the altitude without blowing another limit.
I took Bobs comment as why turn the aircraft 360 degrees, but wouldn't be suprised if he doesn't bother looking.
Take my love
Take my land
I don't care
I'm still free
Take my land
I don't care
I'm still free
Justwannafly
- bob sacamano
So a lookout of 360 degrees but not moving the airplane.... ok.Lurch wrote:Don't turn the A/C 360 degrees, turn your head 360 degrees, I said 360 look-out not turn check. Start at the back window at your side and go around until the back window on the other side.[/quote
Why?...cause someone may be flying behind you. I'magine following someone & all of a sudden they do a 180 right infront of youWhy would you do a 360 look out before a steep turn?![]()
Some instructors use this technique;
if you can't teach em, confuse em.
p.s. not everyone flies a cessna.
Following someone in the practice area? Now come on.
- bob sacamano
Back when I did mine, he wanted me at 4K, wanted the first half of the turn at 30 degrees, and then the second half at 45.Wasn't Me wrote:The PPC is on a PA31-350 the steep turn is part of the ride.
Once to left and to the right.
Note: I thought we were talking about ab initio training earlier on, my mistake.
- bob sacamano
Maverick,Lurch wrote:I took Bobs comment as why turn the aircraft 360 degrees, but wouldn't be suprised if he doesn't bother looking.
Why you gotta take things personally?
Look dude, you keep up this attitude in the practice area, once you're out in the real world, hopefully it would change.
45 degrees isn't a "steep" turn (snicker).
A normal turn is 60 and 2G, imho
You want steep? Start off with 75 and 4G, and increase the bank and G until you either hit your airframe G limit, or your airspeed starts to decline (in level flight) in which case you're power-limited.
Ball in the center the whole time - that goes without saying
Wanna see a real steep turn?
http://superbikeplanet.com/image/2006/m ... d/18st.htm
No paint on his knee and that's a "Steep Turn"?Hedley wrote:45 degrees isn't a "steep" turn (snicker).
