206 Info
- Jumpus Pilotus
I am flying a C-206 jump plane on a 2200' runway. The runway is a mix of asphalt and gravel and was built in 1942. At my knowledge, it has never been maintained in any way.
With six jumpers on board (plus equipment) and fuel for 1.5 hours, I can tell you that on warm days I use almost all of the available runway. Not rare to see corn on the main gear after a flight.
I usually use around 700' to land.
An airplane kills you quickly; a woman takes her time.
- Rank Moderator
- Jumpus Pilotus
When the 206 is used for skydiving, a weight reduction is performed on the plane. Everything useless is removed and the jumpers sit on the floor. The only seat remaining is the pilot seat. Most of them will also have a sliding cargo door installed.endless wrote:one pilot + 6 pax in a 206? I thought you were limited to 5pax and with the newer models only 4pax?
Wing extentions increase the MTOW so it makes it perfectly legal and safe.
We occassionally fly to and from 2000' one-way grass strips in the mountains, but generally, with the loads we carry, 3000' and paved or gravel is the preference.
It's all dependent on the winds, density altitude, temperatures, take-off weight, and what the mission is.
Words of advice: use the P.O.H. It could mean the difference between getting airborne or hitting the trees on departure.
"Come down, your head is in the sky, feet on the ground...come down."
I fly a 206 straight wheels off 2400 feet paved, near sea level.....no problem with a full load, just long slow climb....similar to a loaded 172. It usually gets airborne at about half way down the runway with light winds, fully loaded. When I take off empty, it gets up within a few seconds and probably not much more than a few hundred feet ground roll.
- corn-shoot
With regards to number of passengers carried in a C-206, the insurance company and number of pax insured will be the final deciding factor. And I might add that it is not unheard of for a pilot to knowingly/unknowingly be flying an airplane with the correct number of passengers according to the manufacturer but not in accordance with the insurance policy. Something to check for.
The 206 on wheels is a great short/rough strip performer, but like any airplane will bite you when heavy, high and hot.
Snoopy
Snoopy
- corn-shoot
You were always jealous of that neat little trick. Oh and yeah...they're your buddies alright.corn-shoot wrote:He's full of shit when he says "landed". My buddies at Transport classify his 200ft landings as "CFIT"I am Birddog wrote:With a 20 kt headwind I constantly landed the C206 within 200' with airspeed at bottom of the white arc.
Corn shoot can attest to that.
Mr. Endless, full load of passengers and I can't remember the fuel but we'll say close to full tanks. It was a high approach and started to pull the power back far enough to avoid any shock cooling. Almost an engine out glide onto the surface of the runway. Staying ahead of the power curve the whole time 1000 RPM till 50' above touch down then to idle all the way down after that. The secret is the high approach. And yes it worked better with full load. As far as speed goes...I went from 10 kts above bottom white arc then right at white arc @ 50' above touch down and then slightly below white arc on the flare. Dont ask me the exact speeds because everything is colour coded...right?! full flap 1/2 mile out.
- corn-shoot
