Stowaway's body found in 747 wheelwell
200hr Wonder
the_professor
shitdisturber
- Location: If it's Monday it's got to be somewhere shitty
I seem to remember in the early 70's that people used to sneak out of Cuba in the wheel wells of 707's on a fairly regular basis. The flight being obviously short enough that a fair number of them survived.swede wrote:People have survived this sort of thing, how desperate you would have to be to try it is beyond me.beechy wrote:People have survived this sort of thing before no?
I thought so....I seem to remember reading something about hot air being blown into the wheel well or something.....I wonder if it would be enough to survive, ie not die from hypoxia.......damn it would be a bad way to fly though.......i can't imagine what people must have gone through to be motivated enough to do it.
cptnCanada
Happened at pearson a couple years ago...
also happend in windsor a while back, but I cant find any link to the story[/url]
You're getting the stories mixed up. The man from Senegal was a second incident that happened on the 12th. The original story said the flight came from Heathrow (on the 29th) though they didn't say where they thought the stowaway came from.longjon wrote:UH where in the UK is Senegal, sheezzzz
- Cat Driver
Standing in the customs and immigration booths as you go through Heathrow and Gatwick?UH where in the UK is Senegal, sheezzzz
- blue_side_up
- Location: Caution this posting may contain traces of nuts
Lots of room for a mere human to fit in the nose wheel well of a 747, even with the gear retracted and doors closed. Would be pretty cosy, but I think the first challenge would be to survive the gear retraction sequence without being converted into tire food - nose wheel tires are spinning at around 160kts as the gear retracts, and are only braked by skid pads mounted in the forward of the gear bay, that contact the tires at the end of the retraction sequence. If you survive that then there's lots of space, but it starts to get pretty cold. Better have 3 pairs of woollen underwear and a touque or two for the -55C temps. If you can then survive the 6-10hr flight at that temp, you then have to cling on with frozen fingers as the gear lowers on final at 2-3000', and 180kts.
Good luck to anyone who trys it, but my money will be on the horse races.
Connoisseur of the finest crew meals worldwide
