ultralight weight cut-off??
ski_bum
Post by ski_bum »
Just wondering the weight where a plane is not considered an ultralight? can you log ultralight time and is it good for anything? has anyone heard anything on the stingsport?
oldtimer
Post by oldtimer »
Check the CARS. I heard that they have to give some pilots an enama to get the weight down.
LastSamurai
Post by LastSamurai »
Ski_bum,
here is the only reference to weight that I could find:
401.21--(ii) any single-engined aeroplane having a maximum take-off weight not exceeding 544 kg (1,200 pounds) and a stall speed in the landing configuration (Vso) of not more than 39 knots in which no passengers are carried on board; or
As for logging time, I dont think that you can log ultra-light time however, you can use up to 50 hrs towards an ATPL.
G
boeingboy
Post by boeingboy »
Yes - you can log ultralight time. It is still PIC time.
However, wether an employer would hire you into a hoe or islander with 1000 hrs pic in an ultralight - is highly doubtful.
boeingboy
Post by boeingboy »
Don't forget - there are different catigories of homebuilts.
1) ultralights
2) advanced ultralights
3) exparimental
Each catagory has it's own weight, speed, stall speed, etc....... conditions that it must adhere to for certification in that catagory.
A kit built Lancair will top out at more than 1200 lbs. but it will cruise very high (26,000 ft) and very fast (305 knots) - it would be an experimental. you could probably land a hoe job with 1000 hrs pic in it.
LastSamurai
Your absolutely right BB, thanks for clearing that up :D
Those Lancair's would be a blast to fly... 8)
G
LWhitman
Post by LWhitman »
isnt it true though that you can only log time on advanced and experimental? that was my understanding anyways
Not all Seneca Students are assholes
mikegtzg
Post by mikegtzg »
All time in basic ultralights, advanced ultralights, and amateur built can be logged. I believe the use of the time is restricted.
Recreational permit- An applicant for a Pilot Permit - Recreational - Aeroplane who holds a valid Pilot Permit - Ultra-light Aeroplane may credit all dual and solo flight time acquired in ultra-light aeroplanes towards the experience requirement.
Private pilot license- A maximum of 10 hours pilot-in-command flight time towards the total flight time.
Commercial Pl- a maximum of 25 hours pilot-in-command flight time in three axis ultra-light aeroplanes shall be credited towards the 200 hours total flight time requirement and this time shall not be credited towards the 100 hour pilot-in-command flight time.
If you are trying to build time cheaply to get a higher licence. Fly a small 2 seater registered as a special CofA amateur built, owner maintenance. There is no restriction of time credited.
