Sorry xsbank, my bad.xsbank wrote:That was me ...
 You are such a smarty pants!
Just out of curiosity, what would you be willing to pay for such a device? And where would it be mounted?A breakaway, waterproof, floating ELT isn't rocket science.
ELTs aren't so much "water proof" as they are "water resistant". Besides, if the antenna goes under theres not much you can do.That's no better than if it's strapped to the wreakage. And elt's are waterproof anyway. They are designed to send a signal even when submerged - however there are limitations to how deep they can go before the signal is to weak for anyone to hear.
I don't know of any "sonar" ELTs that are in use. Are you possibly referring to the ULD (underwater locator devices) that are attached to flight recorders?A standard ELT will not work underwater. You need one like the airlines use that sends out a sonar signal.
I'd like to know where that website pulled those stats off. Sure, ELTs can trigger on a hard landing, and other situations, and of course, the ELT isnt perfect, so in some accidents it wont trigger (such as a soft landing in a field in the middle of nowhere?). But to say a 97% false alarm rate and only a 12% trigger rate during accidents?They have a 97% false alarm rate, activate properly in only 12% of crashes, and provide no identification data.
Also discussed previously here:Widow wrote:For commercial float operations, it should be mandatory for the pilot to wear such a personal device, and each life jacket (which the occupants should have to wear during all phases of flight) should likewise be equipped with one.
http://www.masalatalk.com/masalaboard/s ... 714&page=3On June 21, 1994 the FAA recommended the use of 406Mhz ELT’s due to the fact the higher frequency ELT provides more performance and enhances the life-saving benefit of ELT’s, even more so should you need to land in one of the large ponds on the east or west coast of our USA. The FAA also noted that in the year 2009 the international COSPAS-SARSAT satellite system would no longer monitor the frequencies of 121.50 & 243 Mhz; these are of course the frequencies most aircraft ELT’s use today. So how will 121.50/243Mhz ELT be heard you ask? Well, just like they were when the ELT system first came on line, these two frequencies will only be monitored by ground based receivers and aircraft that that happen to be tuned to 121.50/243Mhz on the VHF com, as you can imagine, chances of someone hearing and finding your signal should you actually crash is pretty remote under these conditions. If you think it takes a long time for the satellites to get a fix on your ELT (normally two hours or more), one can only imagine how useless 121.50Mhz ELT will be after 2009. Due to the fact the 121.50Mhz ELT’s false alerts are so frequent, common practice of rescue teams now is to wait for confirmation of the alert by multiple satellite passes, the alert is confirmed by an overdue aircraft or folks on the ground calling the local cops about a smoking hole in the ground.
That's why it's called a break away system.. It doesn't stay with the airplane..That will do a lot of good. Why would you want an elt floating in the wreakage under the water?
For your first question, who cares if it works!CID wrote:Just out of curiosity, what would you be willing to pay for such a device? And where would it be mounted?A breakaway, waterproof, floating ELT isn't rocket science.
Gee, that's kinda funny cause DHC doesn't build airplanes anymore..SAR_YQQ wrote:On DHC products - the correct term is: "Underwater Acoustic Locator Beacon"
It is installed on the airframe and is primarily used to help searchers locate the submerged wreckage.
It self activates upon contact with salt or fresh water and last for up to 30 days.
On the Buffalo - our FDR and CPI (ELT) are both located on a deployable airfoil that automatically detaches itself from the aircraft upon impact or submergence. This airfoil will float and continue to transmit on 243MHz for up to 48 hours. We can also manually deploy the airfield in case of impending crash.
V1CUT wrote:
The type I use is the manual not the automatic, i'm a private owner as well as commercial pilot, i have one for every seat in my personal craft and make my passengers wear them for the duratin of the flight.
Thanks for that - I must have missed the memo.twotter wrote:Gee, that's kinda funny cause DHC doesn't build airplanes anymore..
Or maybe they dropped the "A" on your course to prevent any confusion.It was just a ULB.. Same terminoligy<sic> but maybe in the military's infinite wisdom they have added the extra term..
I'm not sure what you mean by that. I asked what people would pay for an "breakaway floating waterproof ELT". Can you clarify?twotter
Twotter, they are generally referred to as Underwater Locator Devices or ULDs. You might have seen the term used if you ever read CAR 571 standards which contain aircraft maintenance standards.twotter
For your 3rd comment, well, I've never heard of them called ULD, we have always called them ULB's.. Underwater Locator Beacon.. They are not only attached to the FDR, but the CVR as well..
As for the term "flight recorders", generally people undertand that both CVRs and FDRs are "flight recorders" or "aviation recorders" Different manufacturers use different terms. This has become more prevalent recently as there is very little difference technically between either recorder. Some of the new offerings record both voice and flight data. This is especially true for the "dumber" ARINC 573 standard recorder that don't have built in Flight Data Aquisition Units (FDAU).(2) Underwater Locating Devices
The maintenance of ULDs shall be performed in accordance with the recommendations of the ULD manufacturers. In part, the manufacturer recommends that the case of the device and water switch be cleaned at a regular interval to prevent premature discharge of the ULD battery. The location of the ULD should be considered when establishing the periodic cleaning schedule of the case and water switch as it will help to choose the most appropriate frequency.
I don't think anyone implied DHC made airplanes anymore. You see twotter, DHC was purchased by Boeing and then Bombardier years ago and for the most part the brand name was retired for new designs. However, the airplanes that were originally manufactured by deHavilland Canada still retain the "DHC" model prefix. You may be familiar with some of the models like the DHC-1 Chipmunk, the DHC-2 Beaver, the DHC-3 Otter, the DHC-4 Caribou, the DHC-5 Buffalo, the DHC-6 Twin Otter (often affectionately known as the "twotter"), the DHC-7 (known simply as the "Dash 7") and the DHC-8 (know simply as the "Dash 8")twotter
On your course did they teach about the GPS? How about the FLIR? Or the Synthetic Aperture Radar? These are all add-ons that were never installed at production. Twin Otters are often used as special mission aircraft. Many have little more than VHF COM/NAV equipment installed. Others are packed with all kinds of electronic magic. They are quite incredible platforms for special missions.None of them had a UALB when I took their course. It was just a ULB.
