Have you ever hand propped an aircraft?
Have you ever hand-propped an aircraft?
Yes
98
82%
No
22
18%
Total votes: 120
Four1oh
Post by Four1oh »
C-GPFG wrote:
Four1oh wrote:...if you aren't trying to start it, turn it opposite to normal rotation.
I used to do that. I then found out it will ruin the vacuum pump(s).
well, I heard it hurt the magnetos too, but it's not true. I don't know about the vacuum pumps, so what exactly is hard on it?
Drinking outside the box.
Snowgoose
Post by Snowgoose »
I did it on a plane with venturis so I can't speak for the vacuum pump but the engine easily made tbo so I don't think it hurts the mags at all.
I've hand propped a few.. same thing as everyone else has posted so far. Most were on floats.. Only one due to my stupidity of leaving the master on! Never tried it with the beav.. I bet that would be quite the show..
I have however watched someone try and swing start a 172 with pretty horrific results.. slipped.. fell forward.. thankfully the engine only kicked over and didn't start and the downgoing blade struck him across the face. Knocked unconscious and ended up with a lot of stitches.. So Make sure you have some damn good footing and preferably someone in the hot seat on the brakes and ready to shut her down should anything go awry.
youngtimer
Post by youngtimer »
Once on a Champ, under the careful direction and supervision of the owner. It obviously didn't have a starter and was easy to do. Kind of fun to do and a good thing to learn properly for the future when you're stuck somewhere. Mind you, I don't think I could get the ole pt-6 up to 12%, so it might not help now.
heavymetal
Post by heavymetal »
Helped my buddy hand prop a navajo (TIO-540) . I was sitting inside keeping the girl running. He was the human forklift that managed to turn the bastard over. Its amazing what you can do when you are faced with an overnight in Sandy Lake or get the thing started and go home.
I'm never played as the villian in the stories I've told.
donttakeshi*
Post by donttakeshi* »
Just ask Fletcher Lake Lodge the dangers of hand bombing the airplane! He was lucky they were able to reattach his face after the prop hit him in the top of the head.
fogghorn
Post by fogghorn »
Four1oh wrote:
fogghorn wrote:
oldtimer wrote:Do not attempt to hand spike any 6 cylinder aircraft engine. The prop on a 4 banger will always be high enough to hand spike properly. plus with only two compression strokes per revolution, the all important follow through will happen. A six is just too awkward. Most modern airplanes cannot be hand propped unless it has impulse mags. If the mags click when you turn it over, you can hand prop. Forget hand propping a fuel injected engine, it just will not work. If you are hand propping a small airplane like a Cub or Airknocker alone, spike it from behind the prop. If not, chock the wheels. Do not trust brakes and turn on the fuel, prime and pump etc, and then turn the fuel selector off. When the engine starts, you have more than enough time to enter the cockpit and turn the fuel back on. If it gets away from you, it will not go very far.
I have hand bombed a 6 cyl. fuel injected engine. Not out of choice either, it aint pretty, but it can be done..
what plane was that?
185 on floats, I had help in the left seat (non pilot) - I stood on the right hand float and bombed the 3 blade prop with my right arm. The throttle was fully open, mixture lean (after priming) with instructions to my passenger to do the exact opposite once it caught. The reason for this uncomfortable procedure was that we were stuck on a remote lake with a battery with enough juice to run the boost pump and that was it. Not something I would recommend trying at home and I only ever did it once. One thing I have always found, a recip engine always starts better when started by hand, but you have to do it right. Remember that old vehicles like model T's etc did not have starters, they all used those short little nasty hand cranks, but they werent FI'd either. No im not that old - just heard the stories.
You will never live long enough to know it all, so quit being anal about it..
oldtimer
Post by oldtimer »
The old expression says "With patience, perseverance, a small cock and lots of vaseline, you can f@$#k a mouse in the ear"
Which is to say it can be done but should it be done. Hand spiking an airplane is dangerous and should not be attempted except for the small 4 bangers without electrics.
I once knew a hooker who could wrap her lips around the tailpipe and suck start a jet.
try that!!!
fogghorn
Post by fogghorn »
whatever, it all Depends if you want to spend the nite out on some scummy lake in the back of an airplane in the middle of nowhere. The other choice is to do what you can probably do to get out of there, end of story - simply a matter of personal choice.
Four1oh
Post by Four1oh »
heavymetal wrote:Helped my buddy hand prop a navajo (TIO-540) . I was sitting inside keeping the girl running. He was the human forklift that managed to turn the bastard over. Its amazing what you can do when you are faced with an overnight in Sandy Lake or get the thing started and go home.
That's the chieftain, right? I was curious years ago when i flew it, and posed the question to the company's cheif AME, and he said that with shower of sparks, it couldn't be done. I guess he was wrong?
Four1oh
Post by Four1oh »
oldtimer wrote:I once knew a hooker who could wrap her lips around the tailpipe and suck start a jet.
try that!!!
My Sister! She's #2 prostitute in all of northern ontario!
DC3 with some rope and a backhoe? Holy shit Muskeg! :shock: I can't even visualize that one.
Single-Engine IFR
Post by Single-Engine IFR »
I've hand propped several aircraft over the years. The easiest have to be the four cylinder engine tail draggers. Simply tie the tail down, put a chock under the wheel, stand in front and step back as you pull the prop down.
(Nose wheel aircraft are a little more dicey because you have to lean into it as you pull it through.)
Once it's going: walk to the door and turn the fuel on and set the throttle to a low idle, go untie the tail and pick up the chock as you get in the seat.
Some of the most difficult planes I've hand propped:
1. Cessna 175: Six cylinder and geared prop.
2. Cessna 205: Large six cylinder and three-blade prop.
3. Stinson 108-3 with the Lycoming 190 horse power and no impulse coupling or shower-of-sparks. That one kicked back like crazy but I eventually got it going.
SEI
If the good Lord had intended man to fly, He wouldn't have given him railroads.
Hedley
Post by Hedley »
company's chief AME, and he said that with shower of sparks, it couldn't be done
He's wrong. I personally have hand-bombed a 3-blade AEIO-540D4A5 in a Pitts (which does not have impluse coupling, it has shower of sparks/retard breaker) which didn't have enough battery to crank the engine over.
If you're a little guy, though, it just ain't gonna happen. I'm over 6 feet tall and 200 lbs, and it was all I could do, to hand-bomb the 540 with the Hartzell "claw". Needless to say, correct priming is everything.
glorifiedtaxidriver
Post by glorifiedtaxidriver »
co-joe wrote:DC3 with some rope and a backhoe? Holy shit Muskeg! :shock: I can't even visualize that one.
Back up backhoe perpendicular to the airplane, tie one end of rope to backhoe. Wrap the other end of the rope around the prop hub and over itself (don't tie it to the prop). Driving the backhoe away will turn the prop. Do this very carefully, not sure how the engineers would feel about it. (well actually, I'm pretty sure how they'd feel about it) I've heard of it being done with a Norseman and a pickup truck too.
comanchepilot
Post by comanchepilot »
As far as the vacuum pumps are concerned, it is my understanding that the carbon vanes in them are known to chip if it is rotated opposite to its normal direction, which throws it out of balance, and then the pump self destructs.
Any AMEs/Avionics techs out there care to back up this claim?
Retractable pilots do it with their gear up!
Like I said I have done it with a skidoo, it is really quite easy...you just have to know how to wrap the rope around the prop dome.
KenoraPilot
Post by KenoraPilot »
Handbombed a 185, 172 and a Beaver all on floats....the beaver there were two guys though....
rsandor
Post by rsandor »
Expat
Post by Expat »
comanchepilot wrote:As far as the vacuum pumps are concerned, it is my understanding that the carbon vanes in them are known to chip if it is rotated opposite to its normal direction, which throws it out of balance, and then the pump self destructs.
I am not an AME, but I rebuilt my vacuum pumps a few times.
The way they are designed, the carbon vanes are at an angle, and apparently do not like to spin backwards.
Zero Trim
Hand Proppin'
Post by Zero Trim »
Yup, a Beaver and an Otter:
Both tied to a log boom in the middle of nowhere using the good old rope but with a small piece of tuct tape to hold the loop end high on the blade and lots of muscle!
"Your passengers may only remember the landing but you should remember your passengers for the entire flight."
ScudRunner
Post by ScudRunner »
Use to Hand bomb an Islander that thing would fire better than with the starter. Always fun if it was the left engine jumping in the back door and crawling over the junk to get to the Seat.
Once did about 50 consecutive flight hand propping it when out in the sticks and was told that the starter wouldnt be there for another weeks.
God I love Turbines these days!
twotter
Post by twotter »
Cat Driver wrote:I found that it is easier to use a Skidoo..just make sure you have the rope wound the correct way and amount.
But nobody else other than Muskeg is trying to start a 3...
Just be safe people, lot's of good advice here. Get training, treat it like it has a live mag and stay the f*ck away from the prop once it starts..
heavymetal
Hedley wrote:If you're a little guy, though, it just ain't gonna happen. I'm over 6 feet tall and 200 lbs, and it was all I could do, to hand-bomb the 540 with the Hartzell "claw". Needless to say, correct priming is everything.
We tried the standard Navajo priming and start tricks, but it didn't want to catch. Finally we just primmed it till it was pissing fuel and did the flooded start procedure. It caught but barely. I'm not exactly sure how I managed to keep it going, but it was a circus of hands inside running between mixtures, throttle and boost pump to smooth the old girl out. I think it was pure motivation to not stay in in Sandy Lake any longer than we had to.
rsandor I like that picture. It sure has the potential to end badly if that rope got caught in a nick in the prop.
