Exact Oil Temperature
Is there such a device to monitor the true oil temperature while in flight? Something that's independent of the oil temp sensor and gauge on the plane.
I've got a Piper Senica I that's over-temping and I want to see what the true oil temperature before I rip it back apart.
Thanks.
Thanks.
aero-singidunum
aero-singidunum
There is a few instruments (digital) that could be installed and replace all those original Piper instrument cluster.
http://www.insightavionics.com/gemini.htm
well this has all that you need
As nice as that is, I'm just looking for something I can use as a diagnostic tool, I'm not looking to replace any instruments that aren't faulty. I'm just trying to narrow things down for this time, and to find a good tool for the next time this happens.aero-singidunum wrote:There is a few instruments (digital) that could be installed and replace all those original Piper instrument cluster.
aero-singidunum
hangarline
In a nutshell slacker, no there is not anything to independently check your temp in flight. You could however calibrate your guage and probe by putting the probe (while connected to instrument) into a pot of oil and heat it up with a hotplate, heatgun or other source and with a known good thermometer in the pot at the same time, mark your instrument to correspond with the temp of the oil. you really only have to mark 2 or 3 temps to get an idea where you are. Say 140 degress, 180 and 200 or so. You then could fly the aircraft and will then know what your oil temp is doing. There is no real short cut to this problem (been there), just take a systematic approach to troubleshoot it and you will get to the bottom line eventually. Hope this answers your original question.
Re: Exact Oil Temperature
http://www.tiptemp.com/Product.aspx?ProductID=21940
I ended up getting one of these to measure the oil temperature, I put it on a wooden dipstick and can put it right into the oil after the a/c has landed.
Chuck Ellsworth
And for checking the low temp. end of the probe you just shove it up your ass and leave it there for a minute or so....if it reads 98.6 F. when you remove it, it is accurate at the low end also.A very simple way to check the calibration is to put the probe into a kettle with boiling water. We all know what temperature water boils at don't we? No need for fancy equipment. Simple. KISS.
200hr Wonder
Re:
twotter wrote:A very simple way to check the calibration is to put the probe into a kettle with boiling water. We all know what temperature water boils at don't we? No need for fancy equipment. Simple. KISS.
Actually the boiling point of water varies greatly based on Altitude and purity. Certainly distilled water boils at 100C on an ICAO standard day at sea level. Yeah good luck with that...
200hr Wonder
200hr Wonder
"And for checking the low temp. end of the probe you just shove it up your ass and leave it there for a minute or so....if it reads 98.6 F. when you remove it, it is accurate at the low end also."
So could you reference your calibrated ass when you sign out the work?
Chuck Ellsworth
Only if your PMI calibrates it with his probe.So could you reference your calibrated ass when you sign out the work?
Ballsssssss
Just use an infrared thermometer after you get it good and hot. I would try measuring the temp of the oil cooler to see if the oil is bypassing it. This is a simple matter to troubleshoot and trying to find a seperate probe to measure your "true" oil temp seems like a lot of trouble and a waste of time. Listen to the good advice these people on here are telling you. Swapping probes or gauges as well as testing the probe with a heat gun and infrared thermometer are good ideas as well. Maybe you should take your Seneca to an AMO and have a qualified technician look at it.
TT: don't care PIC: still don't care MPIC: really really don't care TURBINE: get a life.
Life's never fair, get a helmet.
Done this already, oil is not bypassing the cooler, they are the same temperatures between engines, and cooler on one side then the other. As for the AMO, well, that's me. I'm an apprentice, the AME is a contractor.Ballsssssss wrote:Just use an infrared thermometer after you get it good and hot. I would try measuring the temp of the oil cooler to see if the oil is bypassing it. This is a simple matter to troubleshoot and trying to find a seperate probe to measure your "true" oil temp seems like a lot of trouble and a waste of time. Listen to the good advice these people on here are telling you. Swapping probes or gauges as well as testing the probe with a heat gun and infrared thermometer are good ideas as well. Maybe you should take your Seneca to an AMO and have a qualified technician look at it.
tired of the ground
are you saying one engine is running cooler than the other?
are they both still in the green?
