Flight duty hours?
CF-UCK
Flight duty hours?
Post by CF-UCK »
lets pretend that 2 years ago i logged 350 hours in my log book in a span of 3 months (when im only allowed 300). If i were to send my log book into TC to get my ATPL issued, and they noticed that i had exceded my flight duty hours, what would happen?
Would they deduct those extra hours?
Not issue the ATPL?
Take away my licence?
Is there a good chance that they wouldnt even notice?
thanks
All Sides
Post by All Sides »
Your allowed to fly 150 hrs. in 30 days, with a reset after 5 days off to 0. Check your CARS there is some latitude
Airtids
Post by Airtids »
It's actually 120 hours in 30 days, unless the company has an Ops Spec in it's COM that allows the bump to 150. Either way, looks like you're clean. Where was your CP on this?
CF-UCK
Post by CF-UCK »
what ever happend to the 300hours in 90 days requirement then?
either way, what are the consequences if you have exceded your duty hours, even if it was a long time ago?
bandit1
Post by bandit1 »
They won't check that. They don't have time for that. Just make sure your totals add up properly and you won't have a problem.
They really like electronic logbooks from my experience.
Question- I heard you're not supposed to log XC and instrument at the same time. I said that was BS but could it be true?
CF-UCK
Post by CF-UCK »
Hot Fuel
Post by Hot Fuel »
Assuming you are operating under 703 Regs...
60 hours in any 7 consecutive days
150 hours in any 30 consecutive days
210 hours in any 42 consecutive days
450 hours in any 90 consecutive days
900 hours in any 180 consecutive days
1200 hours in any 365 consecutive days
The accumulated 30-consecutive day, 42-consecutive day and 90 consecutive day flight times may be reset to zero if the flight crew member is provided with at least 5 consecutive days free from all duty, this does not apply to 704 & 705 regs.
Spokes
Post by Spokes »
bandit1 wrote:Question- I heard you're not supposed to log XC and instrument at the same time. I said that was BS but could it be true?
That seems odd. Isn't a 100nm IFR cross country a requirement for the rating?
Wahunga!
tired of the ground
Post by tired of the ground »
the above only applies when applying for a license/rating. You can't double dip. Say for the night rating, you need 10 hours of instrument right? well, if you do 5 of those hours at night, they can't count as night hours AND instrument hours. You can still log them any way you want.
flying4dollars
Post by flying4dollars »
tired of the ground wrote:the above only applies when applying for a license/rating. You can't double dip. Say for the night rating, you need 10 hours of instrument right? well, if you do 5 of those hours at night, they can't count as night hours AND instrument hours. You can still log them any way you want.
why not? if you're in IMC at night its night IFR (instrument time). Hell even on a high overcast night in the North there's no reference to the ground, no horizion, no city lights. You're pretty much on instruments then.
I dunno, I log night AND instrument if I actually was on instruments that night.
Worst they can do is not accept. But I wouldn't understand why.
Spokes
Post by Spokes »
This only applies for the CPL. Separating these hours is clearly required by the CPL experience requirements. I could not find this separation requirment for the ATPL experience requirements.
Wahunga!
CF-UCK
Post by CF-UCK »
sorry, but now im really confused. these are the numbers i have (straight out of an ATPL book):
60 hours in 7 days (airline or commuter- 40 hours in 7days)
300 hours in 90 days
1200 hours in 365 days
whos right?
phillyfan
Post by phillyfan »
The higher numbers are with the ops spec.
Post by 185/310 »
http://www.tc.gc.ca/CivilAviation/Regse ... ds/720.htm
(a) where the flight crew member conducts single-pilot IFR operations, 8 hours in any 24 consecutive hours;
(b) 60 hours in any 7 consecutive days;
(c) 150 hours in any 30 consecutive days;
(d) 210 hours in any 42 consecutive days;
(amended 1998/03/23; previous version)
(e) 450 hours in any 90 consecutive days;
(f) 900 hours in any 180 consecutive days;
(g) the accumulated 30-consecutive day, 42-consecutive day and 90 consecutive day flight times may be reset to zero if the flight crew member is provided with at least 5 consecutive days free from all duty; and
(h) 1200 hours in any 365 consecutive days.
Then its different from 704/705 operations or if the company has op specs
Forgive me for being ignorant of these rules, but to get " ops spec." to allow your pilots to fly longer hours do you have to show that your pilots are tougher than the average pilot, or dumber?
Spokes
Post by Spokes »
Cat Driver wrote:Forgive me for being ignorant of these rules, but to get " ops spec." to allow your pilots to fly longer hours do you have to show that your pilots are tougher than the average pilot, or dumber?
I think that this system is designed (partially at least I guess), for seasonal type outfits. It can for example let you fly more hours in a month, say 150 instead of 120, as long as you stay in the 1200 annual requirment.
this is of course just an example, but you get the idea.
Wahunga!
Then it would appear that fatigue is linear and can be spread out over the year.
J31
Post by J31 »
whos right?
CAR 702-703-704-705 it is 120 hrs in 30 days, 300 hrs in 90 days, etc. Flight Time Limitations CAR's 700.15 (1) http://www.tc.gc.ca/CivilAviation/Regse ... htm#700_15
CAR 702, 703, 704 DHC-6 non scheduled, or Heli logging with the "Ops Spec" in you can get 150 hrs in 30 days, 450 hrs on 90 days, etc. Flight Time Limitations CAR's 720.15 (1) http://www.tc.gc.ca/CivilAviation/Regse ... htm#720_15
Clear as MUD :wink:
CF-UCK
Post by CF-UCK »
ohhh, i see, i see,
thanks
ScudRunner
Post by ScudRunner »
So here's a better question because you have me worried :lol:
Have any of you ever been rejected or fined etc when submitting your books for the ATPL. I think I was pretty good at cooking the books but you know how it goes.
wtf_over
Post by wtf_over »
Just tell them you have BC mountain time after that it's all a formality :roll:
flying4dollars
. wrote:So here's a better question because you have me worried :lol:
Unless they catch you padding hours big time...the worst they can do is not accept some of the entries. But apparently they dont look at EVERY entry. Just add up #'s to make sure you have what you need?
Maybe I'm wrong, I haven't gotten to that point in my career where I send in my LB yet.
Bushav8er
Post by Bushav8er »
Thats good for flight time limitations...anyone have an easy way to figure the Duty times? Ie. Consecutive hours in a day if...???
Eric Bradley
Re: Flight duty hours?
Post by Eric Bradley »
You can use the FLTDUTY XLS http://www.fltduty.ca software to enter duty and flight times and it will check against the CARs and Standards for the type of operation you are in and warn of impending violations or approaching limits.
CARs are the Regulations and are in the 700's. The Standards are what the ops specs are for and allow you to use the alternatives indicated there instead. Standards are in the 720's.
Eric :^)
Re:
wtf_over wrote:Just tell them you have BC mountain time after that it's all a formality :roll:
:lol:
That's funny...cause we all know BC is the only place with "Real" mountains.
