The End of SEIFR?
Re: The End of SEIFR?
To have any credibility, you have to use an entire quote. To lazy? Read it again.
You don't know much about VMC either, do you. You can easily "park" that twin in the aforementioned farmers field at well below 80. But, the real point here is....YOU get some say as to where you "park".......and, it just might find a way to get you all the way home. But, if you'd rather "glide"....fill yer boots.
airplane rider
Not to wade too deeply into the argument, I only have one comment to make from my point of view. I "threw" a cylinder in a Navajo coming home to Grand Cayman from Cuba on takeoff. The flight is entirely over the ocean. Because it was a twin I was able to reduce the sick engine to near idle, keeping it in reserve, and flew home on the good engine (repairs in Cuba are a nightmare). It was a long flight watching the gauges and hoping for the best, but had it been in a single, my options would have been greatly reduced. I should add that I had no pax as it was a drop-off or I would likely have made a different decision.
I know this really doesn't illustrate the twin over single argument, but under certain flying conditions (mountains, ocean, rocks and trees) I would take a twin ANY day.
Generally speaking, when you have one of the engines fail on either of those airplanes, the only thing the remaining engine is good for is taking you to the scene of the accident.I can bring you home in a Travel Air, Aztec, Twin Comanche, or for that matter a lightly loaded Apache.
It's 131 nautical miles of water between Cuba and Grand Caymen. Were they shooting at you in Cuba or something?airplane rider wrote:Not to wade too deeply into the argument, I only have one comment to make from my point of view. I "threw" a cylinder in a Navajo coming home to Grand Cayman from Cuba on takeoff. The flight is entirely over the ocean. Because it was a twin I was able to reduce the sick engine to near idle, keeping it in reserve, and flew home on the good engine (repairs in Cuba are a nightmare). It was a long flight watching the gauges and hoping for the best, but had it been in a single, my options would have been greatly reduced. I should add that I had no pax as it was a drop-off or I would likely have made a different decision.
CID, that's just not true. You could certainly load them up to make it more difficult on yourself, but properly loaded, in the right hands, they'll bring you home. Even with a slight descent, you can still go a long way on a single engine Twin Comanche. It'll level off and easily maintain 6,000 feet or so.
I've only had one engine failure with a flat engine. That was a carb ice problem on a 150. That ended safely on a highway. Even the engines in light twins are pretty bullet proof.
airplane rider.....the rum is good in Cuba. Cigars are cheap. Some of the women are hot hot hot! I would have been tempted to beat the company credit card to death in a good hotel. That would be a long swim! Glad it worked out.
- quickflight
airplane rider was that, vp-cdl or vp-cmj from cuba.
hook low flare late
airplane rider
I'm sure you can guess...LOL
Yeah, it was CDL, and the left side. I think maybe you were still there actually. The mighty Swede was with me coming back from Cienfuegos after dropping engineers to do boat repairs after Hurricane Denis or Emily.
So...is it safe to say we're better off flying SE VFR in the clag with no air below us? Sorry boys...I'll take the altitude above the weather and a good TAWS system anyday. And I will make sure I know where I am so if things to go south I have my options. At least I'll be sitting in something that's going to get into pretty well any hole I find and walk away from it.
Cheers!
Cheers!
If you can't beat 'em...find a smaller guy to fight!
_69, you have NO idea what you're talking about. Do you? Keep fishing.
Seems I've struck a nerve? what is the use of an open forum when you get shot down for voicing an opinion.
- Cat Driver
Ahhh we have someone who is smart and flies helicopters.At least I'll be sitting in something that's going to get into pretty well any hole I find and walk away from it.
A swing wing? Aw, that's cheaten! Sorry _69.......it all makes perfect sense now.
Helis? No, not my game.
Cat Driver wrote:Ahhh we have someone who is smart and flies helicopters.At least I'll be sitting in something that's going to get into pretty well any hole I find and walk away from it.
[quote="Red Line...The engine is never actually used to more than 75% of it's rated horsepower, the automatic trend monitoring ensures early detection of any abnormalities, devices such as the torque limiter to protect the engine, and let's not forget in the unlikely event of a Py pressure leak or any other issue with the FCU, the MOR lever is there to manually control the FCU and restore engine power (again, something of which the public is never going to be informed). You can't even compare the Pilatus to a Caravan![/quote]
The Caravan has an emergency power lever that by-passes the FCU and directly controls the fuel metering valve.
I have seen with my own eyes an Aztec lose the critical engine at 20' (as soon as the gear doors closed thank good) and climb on one engine to circuit and come around for a safe landing. He had 6 people and fuel onboard, near gross weight.CID wrote:Generally speaking, when you have one of the engines fail on either of those airplanes, the only thing the remaining engine is good for is taking you to the scene of the accident.I can bring you home in a Travel Air, Aztec, Twin Comanche, or for that matter a lightly loaded Apache.
Properly flown, the second engine will take your ass safely to the runway. Your feet will take you to the bar...
Chase lifestyle not metal.
From the Clarenville report: http://www.tsb.gc.ca/en/reports/air/199 ... 8a0067.asp :
1.18 Additional Information
1.18.1 SEIFR Flight
"Prior to adopting a policy on the carrying of passengers on SEIFR flights, Transport Canada (TC) conducted a study on SEIFR and published a position paper in December 1993."
Is this report anywhere to be found?
1.18.1 SEIFR Flight
- quickflight
Airplane rider, I forgot about that, I was on holidays with the kids when that happened. I do remember working on it when I got back. You know with the guy of the same name.
Was talking to the swede recently, thinking about going down there end of Feb for a few days.
hook low flare late
Snoopy, strangely, the "position paper" does not seem to be available ... if anyone has a copy ...
oops, <snip>
oops, <snip>
CD????
This is the simplest arguement i have for having SEIFR. Weather is 1000ft. Would you rather bomb around VFR at 1000ft, or would you rather pop ontop of the cloud at say 8-10k and cruise along.
Say you have a flame out in both situations. At 1000ft you would not have enough time to restart the engine if you didn't catch it soon enough. At 8k you have plenty of time. So at 1000ft you are in the bush waiting for someone to pick you up. At 8k you return to the nearest airport and land.
Lets make it more dire. The engine completely exploids. Engine oil everywhere, on the windscreen, all over the airplane. Once again, 1000ft. You don't have much time plus now you have a windscreen that is completely covered in oil and can't see crap. Not only that but this just happened so your nerves are a little stressed. You manage in the 2-3 minutes to maybe make a mayday call, BIG maybe, and land in the bush without giving your passengers a briefing. Now again at 8-10k. Same but you now have plenty of time to make multiple mayday calls, give your lat and long, give your passengers a full briefing, and you still pop out at 1000ft visual. Your nerves are not as rattled and you are thinking more clearly. If you have a good gps, you can just about map a place to land via the gps. Oh and for the oil you make a plan to get the best vis possible.
Things i don't agree of for SEIFR
1) SEIFR in mountains, (ARE YOU INSANE)
2) SEIFR over large bodies of water, (look up to last remark)
Things i think they should change to make SEIFR more safe
1) GPWS
2) Make a standard for GPS with moving map displays
3) Must have at least 1000ft along the whole route to be flown.
4) SEIFR in mountains not allowed, same as over large bodies of water
1) GPWS
Edo wrote:Red Line wrote:...The engine is never actually used to more than 75% of it's rated horsepower, the automatic trend monitoring ensures early detection of any abnormalities, devices such as the torque limiter to protect the engine, and let's not forget in the unlikely event of a Py pressure leak or any other issue with the FCU, the MOR lever is there to manually control the FCU and restore engine power (again, something of which the public is never going to be informed). You can't even compare the Pilatus to a Caravan!
The metering valve is part of the FCU.
This always turns into a heated 1 vs. 2 engine argument. Do you have a plan of what to do if you have a heart attack? stroke? Do you carry a defibrillator with you. Do you carry a cell phone with 911 dialed and your finger on the send button? PT-6 Engine failures are as likely as a heart attacks in a 30 year old. Yes, it can happen, but not statically likely (especially is you take care of it). Plus in a twin if it happens other problems can follow. Remember the mayday episode of the Brasilia that had a prop failure? One engine was still spinning and they crashed with fatalities. Statiscally it's an unlikely event, that's even part of the certification. Why don't you argue CATSA's security policies, you'll get just as far.rd1331 wrote:This is the simplest arguement i have for having SEIFR. Weather is 1000ft. Would you rather bomb around VFR at 1000ft, or would you rather pop ontop of the cloud at say 8-10k and cruise along.
1) GPWS
Actually, Sno, that question was on another thread....I'll be thinking of you when I feather one (as rare as that is) and bring it home on the other.
My bad, I fixed it.
Oh, and please do as mine will be in the hanger and I will be starting into first plate of hot wings at the bar. Because that's what happens 99,999 times out of 100,000 if I remember TC spec correctly. Buffalo style, no breading and a nice Kilkenny to wash it all down.
