Mississauga noise signs
abc xyz
Post by abc xyz »
After dropping the old lady off at work this morning I saw these new signs that Mississauga has put up telling everybody about aircraft noise. They were right under the flight path to rwy 5 on Mavis. Good idea or bad???? Obviously they have evolved because somebody got sued or good ole Hazel is getting soft.
http://www.mississauga.ca/file/COM/Airc ... arning.pdf
Just an average man doing heroes work
FL_CH
Re: Mississauga noise signs
Post by FL_CH »
they should add at the bottom:
"...you were warned, now STFU about it"
Grey_Wolf
Post by Grey_Wolf »
Ditto for the City Centre Airport :smt040
ScudRunner
Post by ScudRunner »
Or the ever popular signs on the roof campaign to give pilots something to laugh about.
FL_CH
Post by FL_CH »
Doesn't it just make you want to go right overhead at 50 ft at full power?
Northern Skies
Post by Northern Skies »
LOL, that reminds me of the guy at the end of 24 at YSN. He's always up to some crazy scheme, I think the airport even has a restraining order against him. I don't even think he owns the place there, just a renter.
Anyway, he used to mow F**K OFF PILOTS into his lawn all the time!
Blakey
Post by Blakey »
Northern Skies wrote:LOL, that reminds me of the guy at the end of 24 at YSN. He's always up to some crazy scheme, I think the airport even has a restraining order against him. I don't even think he owns the place there, just a renter.
I personally recommend a big sign that says "Welcome to Brantford". That would get some attention!
FL_CH wrote:Doesn't it just make you want to go right overhead at 50 ft at full power?
25 feet if I'm thinking about landing in uncontrolled airspace in his neighbour's yard, in which at the last minute, I spied a person and/or unsafe frog which made me overshoot in the interests of safety. In a 747.
-istp :wink:
