Am I allowed to?
MCRS
Re: Am I allowed to?
Post by MCRS »
Niss:
How lucky are you to have a plasma cutter! Well, then go for it! Draw it out cut it out and present it to your AME.
Mind you I am not sure what all your planning to do but if your cracking open Pitot and static lines ect to reroute all you instruments, switches and radios then you better make sure you let the AME either do the switch over or get his okie dokie to do the work yourself with hime checking up on it every so often. If your just leaving everything where it is and making it perdyer then just get his advice about if you can do it and The AME check it when your done or whatever your AME feels comfortable with.
mcrs
.... Maintenance is a science since it's execution relies, sooner or later, on most or all of the sciences. Lindley R. Higgins Maintenance Engineering Handbook; Mcgraw-Hill, NY, 1990.. Look ma, I'm a Scientist!
SeptRepair
Post by SeptRepair »
I have yet to see an instrument panel cut using a plasma cutter that gave any resemblance of quality. The best luck we have had in making instrument panels with precision are done by water jet.
twotter
Post by twotter »
wrenchturner wrote:
CID wrote:twotter's right.
Anybody else shocked to see those words from CID??
Mostly me!!! See boys and girls, anything is possible..
BTW thanks CID...
BoostedNihilist
Post by BoostedNihilist »
I smell a hippy love fest
KISS_MY_TCAS
Post by KISS_MY_TCAS »
Well, I stand corrected. Some excellent points raised.
And I agree with SeptRepair, from experience find a waterjet cutter.
Return to “Maintenance”
