Pay and Benefits
Any comments or suggestions can be placed here.
TTJJ
Pay and Benefits
Post by TTJJ »
To the administrator:
I request that a permanent forum be established in "employment" where members could state their position (Capt., F/O, Ramp, etc) salary and benefits, work conditions(ie loading own aircraft, hard IFR most of the time etc) and flight times, as well as their aircraft flown and geographic location.
Said forum would have only values and information, not rants.
It would serve as a reference for pilots seeking employment or comparing their salaries with others so employed.
Other aviation sites have this item. I believe that it would be of benefit to our members in Canada and abroad.
There have been threads along this line already posted here. The threads get lost however over time thus indicating the need for a more permanent solution.
I would appreciate an e-mail from you with your thoughts on this matter.
Thank you
TJ ( Late of Winnipeg, now pounding back the brewskys in Brazi
avcanada
Rank Admin
Rank Admin
Post by avcanada »
I like your idea and am in the middle of publishing the AvCanada salary survey which will have all of the above info more or less. When I am done I will publis the results in the new forum and allow users to post salary/benefit topics for added discussion.
Joe
TTJJ
Post by TTJJ »
Thank you for your swift reply
Spaceship 2
Post by Spaceship 2 »
That is a good idea TJ. The salary survey is along these lines, however a more finite sounding thing. A forum with this topic would be ongoing. Although I suppose people would start ranting away as we occasionally do :wink:
and to Avcanada, is that survey going to be published on this site? And when do you figure it will go up?
thanks
Return to “Forum Suggestion and Announcements”
