Instrument Requirements for IFR
TopperHarley
Hey guys,
From the Aerocourse ATP Workbook:
"Which of the following meets the min radio nav equipment required for an a/c operated by an air taxi operation, in IFR flight on an air route:
a. 1 RNAV and 1 GPS.
b. 1 VOR/ILS and 1 ADF.
c. 1 ADF.
d. 1 ADF and 1 GPS.
The correct answer is d. I know that a and c cannot be correct; however, I do not understand why b is incorrect.
If instead of saying "1 VOR/ILS and 1 ADF" it read "1 VOR/DME and 1 ADF," then would it also be acceptable? I believe that you need to have a VOR/DME combo in order to operate IFR (i.e. it can't just be VOR), but I have not been able to find a source for this.
The other thing that kind of threw me off on this question is the "air route" part. I understand that an air route is uncontrolled airspace (as opposed to an airway).
Thanks for all comments,
Chris.
c. 1 ADF.
d. 1 ADF and 1 GPS.
Chris.
"Never travel faster than your guardian angel can fly." - Mother Theresa
jackrabbit
I remember seeing that question and answering wrong as well. Sitting there thinking about it, the only explanation I can come up with is this.
I have never seen an airport that has IFR approaches without a beacon on or by the field, but there are tons of them without a VOR. The VOR in your airplane is useless at the airport with the NDB A approach. However, many of theses airports now have GPS or some type of RNAV approach.
I know that's kind of stretching it but....... maybe someone else has a better explanantion.
Tango01 wrote: If it was VFR, you would need a GPS. CAR 723.28
CAR 723.28 wrote:723.28 VFR Flight Minima - Uncontrolled Airspace
The standard for reduced VFR limits of one mile in uncontrolled airspace is as follows...
Here's what I think of this: if you fly IFR, you need to be able to navigate even if you lose one of your navigation equipment.
With the VOR/ILS - ADF combo, you would need an air route covered by both VOR and NDB stations. Which is not all that common in uncontrolled airspace. On a NDB - NDB air route, if you lose the ADF, you can't continue with your VOR...
Or they just made the common mistake that an air route is a ndb-ndb route...
Benwa
- Cat Driver
Hmmmmmmmm..
Answer is D...
How many airplanes being operated IFR in 2005 would have an IFR certified GPS and the only other working nav aid was an ADF???
Or am I just getting senile and can't see the picture?
Cat
Answer is D...
Cat
What would've been the answer 8-10 years ago? What has changed? You're not using a study guide produced by a guy whose name rhymes with 'No Shame" are you?
Before the GPS era, a good answer would've been flying with 2 ADFs.
You will not find anything specific in the CARs, they wrote the regulation without reference to specific navigation equipment on purpose.
As mentioned in this Policy Letter.
http://www.tc.gc.ca/CivilAviation/comme ... /PL142.htm
- Spiraldive
C-hris:
The rule is actually fairly simple: The rule is based on where you are flying and what you need to get there. The last of a whole heap of regs about it says:
605.11 to 605.13 Reserved
(j) sufficient radio navigation equipment to permit the pilot, in the event of the failure at any stage of the flight of any item of that equipment, including any associated flight instrument display,
(i) to proceed to the destination aerodrome or proceed to another aerodrome that is suitable for landing, and
(ii) where the aircraft is operated in IMC, to complete an instrument approach and, if necessary, conduct a missed approach procedure.
So (b) is wrong because if you lose the only adf you have on an air route, and the only backup equipment you have only reads vors, you're fucked. The VOR/ILS do nothing for you in that case, so its up to you to figure out if you've got enough ifr stuff for any given flight.
(d) is correct, because the GPS qualifies (if it and you are certified) as the "second" piece of equipment. You can still get there with the gps-only if the adf fails, or the adf-only if the gps fails. The vor is just useless weight for that particular flight. They are trying to see if you know the difference between the mx regs (ie. the equipment required to get a plane certified in the first place, v.s indicator, oat gauge and all that shit), and the interpretive part of the regs.
Dual adfs would qualify too, on an air route.
It's that easy.
It's that easy.
- Spiraldive
Benwa:
You're right. Forgot that airoutes come in the vor/vor format too. Frankly, never flown on one in that format either. Most of them are adf somewhere along the line. Aerocourse was probably assuming the adf thing in the original question, hence the gps/adf answer. They do need to specify the radio aids available on the route to ask that question and expect an answer.
And in answer to your other question, same rule applies. An ndb to vor airoute: Then you'd need either gps/adf/vor (gps lets you fly vor or adf), or dual adf/vor's. Alternate equipment not included.
- Cat Driver
Sorry Cat, you can't. Unless they changed that.Our good friends at TC wrote:GPS is approved as a supplemental navigation system for enroute and terminal operations, and as the “primary” means of navigation during a stand-alone non-precision approach. As well, Canada Air Pilot General (CAP GEN) and Aeronautical Information Publication (AIP), Rules of the Air (RAC) Section 3.14.1 do not permit the use of GPS approach minima to determine the suitability of an alternate aerodrome for flight planning purposes. This limitation restricts the flexibility to use GPS receiver, as compared to a traditional navigation aid such as VOR or ADF.
Benwa
- Cat Driver
Funny thing is I have been using GPS all over the world for years and can only recall two very short interrupted receptions, and they were both caused by poor placement of the antenna on a handheld.
Once turning final at Bourdeaux France, it was off for about ten seconds and the other time was just approaching Bamaco, Mali in Africa...that time the antenna fell on the floor.
I prefeer the Anywheremap because I can mount the thing right in front of me on the glareshield, sort of like a quasi HUD.
By the way we run three or four GPS units all the time and seldom see any difference in the info being displayed beyond a knot or so difference in GS due to repeatability set to set.
Cat
Cat
Yeah this was the first and only time anything bad happened with the GPS.
There was a lot of solar activity causing electromagnetic irregularities.
I use PocketFMS on my PocketPC, it's really good... and it's free !!!
Try it out, if you find any bugs, you just write to Rob and he's quite fast at fixing it. Being on the software subject, I also recommend AirPlan, I've been using it for over 4 years now. It's awesome.
- Spiraldive
Benwa:
You're not right.
At least about the gps-alternate.
They have changed the rules. You can file a gps-only airport as an alternate (as in no adf onsite, gps approach only) under a bunch of conditions. If the airport has a traditional approach aid, you have to use those minima for alternate requirements.
Your destination must be served by a conventional navaid. You must establish raim at the alternate before you leave the ground (by asking fss for the satellite notams and checking them against the office copy of the world gps satellite almanac, yeah, like that'll happen, or turning the avionics on). Then you have to check the raim again for the alternate before you reach halfway to your destination.
And I believe two ifr-gps units would qualify. TC no longer requires the monitoring of conventional underlying approach aids if you are shooting a conventional non-precision approach using gps information.
You're not right.
TopperHarley
SpiralDive,
There is one thing that I have not been able to find the answer to regarding GPS-use at alternate airports. You mentionned that if there is a traditional instrument approach at the alternate as well (NDB, ILS, VOR), you use those mins; however, what if the airport only has GPS approaches available? Will the mins be based on whether you have VNAV capability or not? (i.e. if you only have LNAV, then the mins are 800-2; if you have VNAV, the mins are 600-2, etc)?
Thanks in advance,
Chris.
Thanks in advance,
Chris.
- Spiraldive
C-hris:
V-nav is as yet not authorized for use shooting gps approaches. I suspect it's coming with WAAS and the placement of ground-based gps trancievers at airports, but as of yet you can't use it at all. They just have a place for it on the plates in anticipation.
When it does come in, I guess they'll have to decide whether v-nav qualifies as a precision approach. Knowing TC, they'll probably come up with a new standard like 742' and 2 5/16miles.
But for now, the mins are the standard non-precision 800-2 for filing gps-only alternates.
Also, I see from the July aip amendment, they now allow you to use the gps minimums at your alternate regardless of whether there is a traditional approach aid there. But if you do, you're not allowed to plan to shoot a GPS approach at your destination, you must use the traditional aid.
Spiraldive wrote:And I believe two ifr-gps units would qualify.
Is that still true ? If so, you can't fly the EnRoute part with only 2 GPS units. You'd need the traditional equipment.Transport Canada wrote:GPS is approved as a supplemental navigation system for enroute and terminal operations
