Composite Flight Plan
AuxBatOn
Post by AuxBatOn »
I've got a question for anyone that could help... I want to fly a VFR departure, bum around low level for a while then climb and proceed to destination IFR. I know I can file a composite flight plan (Z as the Flight Rules). I'm flying low level (300' AGL/420 kts g/s) from Moose Jaw to the YDR233/70, then FL390, M0.70 to Thunder Bay (DCT YDR DCT YWG DCT VBI J500 YQT). What do I put in the altitude, speed and routing portion?
AuxBatOn
Going for the deck at corner
lilfssister
Re: Composite Flight Plan
Post by lilfssister »
(300' AGL/420 kts g/s) Moose Jaw YDR233/70, FL390, M0.70 to Thunder Bay (DCT YDR DCT YWG DCT VBI J500 YQT).
AuxBatOn
Post by AuxBatOn »
Hmmmm.. Sorry my ignorance, but where do I specify the change in flight rules and what do I put for VFR routing?
just curious
Post by just curious »
The FL390 part will alert the obtuse that you will be IFR at that point. For routing, can you specify a CYR you'll be in, or a radius of, say, the YMJ 053/25?
nimbostratus
Post by nimbostratus »
AuxBatOn wrote:I've got a question for anyone that could help... I want to fly a VFR departure, bum around low level for a while then climb and proceed to destination IFR. I know I can file a composite flight plan (Z as the Flight Rules). I'm flying low level (300' AGL/420 kts g/s) from Moose Jaw to the YDR233/70, then FL390, M0.70 to Thunder Bay (DCT YDR DCT YWG DCT VBI J500 YQT). What do I put in the altitude, speed and routing portion?
AuxBatOn
Are you planning on having a wicked tailwind at low level? If not maybe a slower speed would be more appropriate for that altitude.... (perhaps 250kts or less until 10,000'?)
Si Hoc Legere Scis Nimium Eruditionis Habes!
"Man is least himself when he talks in his own person.
Give him a mask and he will tell the truth." -- Oscar Wilde
AuxBatOn
Post by AuxBatOn »
NS, we have the authorization to fly fast at low level in our Low Level Training Area. It's all legal...
AuxBatOn
Post by AuxBatOn »
just curious wrote:The FL390 part will alert the obtuse that you will be IFR at that point. For routing, can you specify a CYR you'll be in, or a radius of, say, the YMJ 053/25?
We won't be in a CYR. We have a low level route that we fly. I'll just put YDR233/70 in the VFR part of the flight plan. That should suffice. That way, ATC knows where I'll open the IFR part of the flight plan.
Thanks!
nimbostratus
AuxBatOn wrote:NS, we have the authorization to fly fast at low level in our Low Level Training Area. It's all legal...
That rocks man! 8)
wannabepilot
Post by wannabepilot »
Here in Fort McMurray a lot of charter aircraft like to do an oilsands tour after departure (20-30 NM NW) then pick up the IFR directly from center. In those situations they usually file an IFR plan, and the FSS gets them approval for a VFR departure with instructions to contact center when their tour is complete. A little less complicated, but I couldn't say if every center would be as accommodating. And, for a long-ish VFR leg, like the 70 miles you're proposing, filing composite is still probably the best way to go.
