In otherwords even IF you have right of way, if you see the possibility of a conflict YOU are responsible to give way. Deliberatly turning in tight just to screw with somebody violates this rule. If the dickhead pilots of the Lear are not willing to concede your right of way to you, it unfortunatly becomes their's. The 'notwithstanding' part of the reg makes it pretty damn clear that regardless of who is actually in the right at the start of this situation, NOBODY was in right by the time it was done (assuming all the details given in the original post are accurate)602.19 (1) Notwithstanding any other provision of this section,
(a) the pilot-in-command of an aircraft that has the right of way shall, if there is any risk of collision, take such action as is necessary to avoid collision
Just to futhur prove the point that nobody was right, the final item of reg 602.19 states:
As someone else already said, the easiest and safest way out of this would have been for either the Lear to join the active runway (although a lear in the cct with a few cessnas isn't exactly ideal) or the cessna to extend (the best choice in my opinion). Just because you have right away doesn't mean you can't be polite.10) No person shall conduct or attempt to conduct a take-off or landing in an aircraft until there is no apparent risk of collision with any aircraft, person, vessel, vehicle or structure in the take-off or landing path.
