Sure. Like I said earlier, if you know the other pilot,Could a landing aircraft not wave the 200ft rule for another aircraft
you can declare that you are a "formation".
I do formation takeoffs and landings all the time -
perfectly legal.
It has nothing to do with formation... you can't be in formation with a mower. Formation flights apply their own landing or take-off seperation they don't hold at the threshold while another aircraft lands. There's a reference for controllers that we can have men, equipment or even planes inside of 200' from the runway, as long as no danger exists to the landing aircraft. So when a lear jet is departing and you have a mower at the edge of the runway 500' from the threshold, things are pretty safe. If we ask you and you agree, it's just confirmation that it's safe. On the other hand, having a plane at the edge of the threshold with another landing... not many controllers would feel comfortable putting their licence out there for that because a danger definitely exists no matter what the landing pilot says. I'm not sure how this rule applies to FSS on uncontrolled fields. Turn around bays are not intended for holding bays, due to this reason. Holding bays have the appropriate clearance and a hold short line which may or may not be 200' from the rwy edge but deemed far enough by TC, the same as taxiways.Hedley wrote:Sure. Like I said earlier, if you know the other pilot,Could a landing aircraft not wave the 200ft rule for another aircraft
perfectly legal.
Got a CARs quote for that? Hint: there isn't one.Formation flights ... don't hold at the threshold while another aircraft lands
... and in a thimble, exquisitely illustrates the fundamentalnot many controllers would feel comfortable putting their licence out there
Hedley wrote:Got a CARs quote for that?Formation flights ... don't hold at the threshold while another aircraft lands
I think you'd be pretty hard pressed to convince someone that you're in formation with the Westjet 737 on final and would like to taxi down to the turn around bay and hold next to the threshold while he lands. The only time you can consider yourself one flight is when you have made a prior arrangement and then you are cleared for each operation as one. I can't taxi you to the turn around bay and clear your partner to land under a single clearance so you can't do it. If you are both arriving and I clear you to land, you still need a clearance to backtrack. If you are both departing then I'll clear you both for take-off and one can hold in the turn around bay as the other rolls or you can both roll at the same time, that's your discretion. Trying to tell me that you're a formation flight with the guy that is landing when you're getting ready to depart makes about as much sense as telling me that your in formation with the lawnmower cutting the grass. If you falsely tell me that you're in formation with someone that didn't agree to it, and then proceed to run into him, he'll have your ass at any court in this country.12.13 Formation Flight Procedures
12.13.1 General
Formation flight is considered to be more than one aircraft which, by prior arrangement between each of the pilots involved within the formation, operates as a single aircraft with regard to navigation and ATC procedures. Separation between aircraft within the formation is the responsibility of the flight leader and the pilots of the other aircraft within the formation. This includes transition periods when aircraft within the formation are manœuvring to attain separation from each other to effect individual control, and during join-up and breakaway.
Hedley, we have F18's arrive in formation regularly. You're right, they're in formation and for a split second, going different directions as they do their overheard break. The thing is when they come in, they are communicating as one aircraft and still confined to the rules of ATC as one aircraft. I tell the lead to break right and no matter how many aircraft are following, they are required to break right, not at the same time as they are allowed to provide their own spacing as the reference states. As they break I clear the lead to land and all the following aircraft are then cleared to land and yes there is no separation standard between the formation like there is with two separate flights. This doesn't mean that the runway is theirs and if there are 5 on the ground and 5 in the air landing and departing all as one, you can have planes backtracking, with planes landing over top of planes going the other way, and other planes rolling etc. They are still bound to ATC rules as one flight. Just as one flight can't backtrack on their own without a clearance, neither can any aircraft in formation. They have to exit as any other flight would and need a clearance to backtrack as any other flight does. In the same way, if I clear an aircraft into position, another aircraft that says he is in formation can go to position with him but you can't have his buddy on final land without a clearance simply because they are a formation. If they were both on approach and I clear the lead to land, then you can land beside him but only then, after the lead is issued a clearance to land.Hedley wrote:Er, no Mitch, he didn't.
Are you trying to tell me that because the two
aircraft are going in different directions, they
aren't in formation?
Hogwash. Ever seen a flight do an overhead
break? The lead is certainly flying a different
direction than #4!
I'm going to say this again slowly, for the
clearly learning impaired here:
Just because something is unusual to you,
doesn't make it illegal.
There's your mistake.There's nothing there that would allow what you're suggesting
The CARs don't support your position.it doesn't at all fit the clear definition of formation flying
My definition of formation does not contravene any CAR.what is and what isn't a formation
If you say so.your penis is bigger than mine
specifically, what CAR have I contravened? Itbut you're still wrong
This is in place because once you start publishing regulation, there will always be those that argue since it isn't specifically disallowed, it is therefore allowed as justification for doing what they want. And in one way this is OK as it does push boundaries, but it isn't OK in that to stop dangerous behaviour we have to have more and more regulations to fill the holes. So if we don't regulate ourselves, TC will eventually do it for us.CARS 602.01 wrote:602.01 No person shall operate an aircraft in such a reckless or negligent manner as to endanger or be likely to endanger the life or property of any person.
If you read 1b it mentions "care expected of a reasonably prudent person in like circumstances" which seems pretty vague. But it allows for a ruling where there isn't a specific regulation and is judged by comparing to the community in general. In a case like this where just using the people who have posted and all are opposed to the suggested behaviour and one is for it, I think it's more likely that the majority establish what reasonably prudent people would do and the one is perhaps being negligent.Merriam-Webster wrote:1 a: marked by or given to neglect especially habitually or culpably b: failing to exercise the care expected of a reasonably prudent person in like circumstances
2: marked by a carelessly easy manner
So, if we have ten people, and nine of them, who flunkedI think it's more likely that the majority establish
I hold a European Airdisplay Authority Hedley....in fact I flew in the European air show circuit from 1997 until 2005 ......like you I have been denied the right to fly in Canada but Europe had no problems authorizing me.Who else holds such a card?
