avionics Q? antenna test
scouty-dog
Post by scouty-dog »
ok guys/gals:
What do most people find the best way to test the SWR of an antenna/co-ax? (ie: what brand of tester) Do some testers also simulate a dummy load when checking 'transmit' watts? I'm looking at a few test sets, and curious what people find works best for them? I'm open to any suggestions.
thanks
Strega
Re: avionics Q? antenna test
Post by Strega »
send me the details of your setup, and I can help, I've tuned a whole bunch of antennas..
What SWR meter do you have? the CB one from Radio shack with PL-259 connectors wont work..
Cheers..
S
scouty-dog
thanks Strega
I'm thinking of purchasing a diamond test set. I would like something that can test within the 118-136 MHZ, as well as checking the transciever power.
Would I get any weird readings if I made a jumper to adapt a M-J adaptor to BNC?
What would you recommend?
thanks
jetdoc
Post by jetdoc »
I thought the standard was the good old Bird wattmeter, can get with various power slugs test output power and SWR.
"Morality is doing what is right, regardless what we are told;
Religious dogma is doing what we are told, no matter what is right."
scouty-dog
that's probably what i'm looking at anyways. Birds sure hold their value.
scouty-dog
So, I went with the trusty Bird 43. What slugs would work for testing primarily FM and VHF?
Has anyone tried the peak power kit?
Return to “Maintenance”
