kingeddie
Re: Pic from a swamper
Post by kingeddie »
Woodland Caribou
2008 caribou flights feb 26 115.jpg (26.38 KiB) Viewed 4042 times
kingeddie
Post by kingeddie »
Helitorch/NVG Tanker/ On the rocks
kingeddie
Post by kingeddie »
A few more from the old CD pile
Before and after OOPPS
kingeddie
Post by kingeddie »
Happy New year
Me in 3.JPG (33.48 KiB) Viewed 3989 times
kingeddie
Post by kingeddie »
Heli Pics
1000 HP
Post by 1000 HP »
Cree Lake early in 2008
Cree Lake BNA.jpg (51.2 KiB) Viewed 3842 times
mag check
Post by mag check »
Cool pics, But I thought that to drop anything out of an aircraft, you need to wear a chute?
I could be wrong, as I'm sure that the MNR would follow all the regs :roll:
C-GGGQ
Post by C-GGGQ »
I believe the reg only states that you cannot drop anything if it poses a threat to persons or property. I don't remember anything about wearing a chute.
CLguy
Post by CLguy »
No such regulation. Not sure where you dug that up from!! MNR has been dropping stuff from airplanes and helicopters for almost 80 years and don't own any parachutes.
Johnny#5
Post by Johnny#5 »
Just from a picture, how do you tell the difference between a 215T and a 415?
mag check
Post by mag check »
CLguy wrote:No such regulation. Not sure where you dug that up from!! MNR has been dropping stuff from airplanes and helicopters for almost 80 years and don't own any parachutes.
Well, I know that dropping skydivers the pilot needs a chute, and I'm pretty sure that somewhere in the regs it says that any air drop needs one. I'll look into it.
mag check
Post by mag check »
Hmmm, guess I'm wrong, can't find it. All I can find is that you can't create a "hazard" to anyone or thing. Not too sure how to drop something from an aircraft without creating a hazard, but at least you don't need a chute :smt040
Bushav8er
Post by Bushav8er »
Dropping of Objects
602.23 No person shall create a hazard to persons or property on the surface by dropping an object from an aircraft in flight.
C-GGGQ
Post by C-GGGQ »
mag check wrote: Well, I know that dropping skydivers the pilot needs a chute, and I'm pretty sure that somewhere in the regs it says that any air drop needs one. I'll look into it.
Hmmm, guess I'm wrong, can't find it. All I can find is that you can't create a "hazard" to anyone or thing. Not too sure how to drop something from an aircraft without creating a hazard, but at least you don't need a chute :smt040[/quote]
yeah the skydive pilot i was with didn't wear one. and as long as you aren't aiming at a person or property (building) you aren't posing a hazard. (see amatuer flower bombing competetions)
just curious
Post by just curious »
Took me a while to figure out what you were talking about, but I'm pretty sure that the pic of the helo with the bag going out the door would have been taken from the boat maybe 6 feet below. A chute isn't going to help.
mag check
Post by mag check »
Sorry for the minor de-rail, on with the pics :lol:
kingeddie
Post by kingeddie »
There are regs you are correct .. There are also exemptions in the form of commercial ops specs .. The picture is of fire hose being free dropped to fire crews on the ground that are building line around a fire front, hose lays can be miles long through areas where there are no landing areas and if the crews carried the hose from the landing area the fire would likely have burned over the area we are trying to contain . There also ops specs we use for entering or exiting an aircraft while it is in flight (no parachute) . For fire fighting , preservation of human life and operating under authourity of a police agency there are many exemptions . Water bucketing , water bombing and dropping of supplies are only a few..
Eddie
Basic Flying Rules: 'Try to stay in the middle of the air. Do not go near
the edges of it. The edges of the air can be recognized by the appearance
of ground, buildings, sea, trees and interstellar space. It is much more
difficult to fly there.'
CLguy
Post by CLguy »
Johnny the only way is if the waterdoors are in the picture. The 215T has the old system which is 2 larger drop doors on the bottom of the hull and the 415 has 4 smaller doors. You can also tell if the picture is of the cockpit. The 415 is glass and the 215T has the older style instruments.
Bush Man
Post by Bush Man »
On with the pics ......
Post by sky's the limit »
On with the pix.
Non-Canadian bush.... But I think it qualifies.
Just another canuck
Post by Just another canuck »
Not Canadian bush either.... but still good.
So throw off the bowlines.
Explore. Dream. Discover.
Rudder Bug
Post by Rudder Bug »
Canuck
This looks like and Islander dash, an Islander nose and an Islander airstrip! Where was that???
Just another canuck
Rudder Bug wrote:Canuck
That is a Caravan my friend.... and it's in a place called Sinak in West Papua, Indonesia. Runway is at 7000' with a 12% incline. You usually land with close to full power cause of the altitude... and sink you get off that little bump at then end of the runway. Doesn't look like much but it sure has some effect.
Cheers.
JAC
tiny
Post by tiny »
JAC, who are you flying for in Papua?
Tiny
Rudder Bug
I should have look a little better before posting. BN-2's usually don't have a prop spinning up front! :mrgreen:
