Engine Failures
- cloudrunner
Engine Failures
No doubt, there are hundreds of thousands of collective flying hours amongst us all here. Just curious as to how many of you have suffered engine failures (not hiccups or roughness...actual failures) twins, singles whatever. What was the scenario and what was the outcome? I myself have never had one go in 3200 hours. There is a point to my question but will hold off for now.
Fill the Oil..Check the Fuel
Never had a engine fail but have had other big problems. Once had to hand crank the gear down, anyone who has flown a 300 series cessna can tell you its not fun. Not that it would be much fun in any airplane. One un-lucky guy I flew with in flight school had a engine fail in a 150 and landed in a feild. Also i have seen a few engines fail on a DC3 but nothing the pilots could not handle.
The FCU is a BFM
Climbing through 4000', got a low oil pressure light on a Metro. Checked the gauge, oil pressure was barely in the green. Ran the checklist, decided to power back the engine and return to land at departure airport. Engine failed 400' short final. Made for a squirly landing.
- jumperdumper
5000 hours with 6 engines failures. 5 on the Super DC3 and 1 on the AT98. Actuall did a 3 engine ferry out of Bronson Creek with that 1. Many other urgent problems that did not result in an engine failure. Heater fire in Inuvik on the ground. Many broken throttle cables on the DC3, runaway prop, stuck elevator in a Navajo. These are just a few that come to mind. 1 of the 6 failures forced us to actually lighten the load over the Atlantic.
3900 hours, 3 enging failures in single pistons as a student -2 due to induction icing in PA28-140, 3rd the engine just came apart. 3 engine shutdowns in King Air due to false fire indications, and 1 partial engine failure due to hot section failing on climb out.
I've been kinda unlucky.
Cheers.
Cheers.
Chase lifestyle not metal.
13 years, 6 engine failures. 3 in BN2's, 3 in AC500's.
3 of them I voluntarily shut down do to impending doom.
3 of them shutdown without any volunteering.
I'm sure everyone has a fish story, so I won't bore you, but lets just say I've had to buy new boxers at least once.
But I'm yet to put one in...... Knock Knock.
Used to have a couple a week in a Beech 18 on Floats, but they were all self induced. Late nights, early mornings, heading north, both engines pulling from the nose tank. Sure wakes you up though!
Actually close to 8000 hours and never a failure! I always chuckled while flying the CL-215, when you would hear the comments, we need turbines because the radials are old and unreliable. I have been flying radials since 1979 and never had one let me down yet. Shut down a few as a precaution but that is it.
One of our check pilots, who has since retired told me that he had 3 engine failures in his career whch spanned over 35 years and they were all on turbines. So much for the unreliability of the piston engine myth!!!
9000 hrs, 3 radials: 1 seized, 1 came out through the cowl with a fire, one (only one there) limped home w/ plugged screen.
500 turbine failures; 5,000 jet failures in the sim!
1 elevator trim tab on a Beav - think its called a 'phugoid' - landed by the Lions Gate Bridge and taxiied a loooong way back.
Jammed controls on an AC6T on short final.
3800 hours, four piston shutdowns, one complete failure.
Multiple electrical problems (including complete failure just after punching in IMC on climb-out
), and had a gear handle snap off in my hand while doing a manual extension (cause the front engine had already been shut down!!).
One sort of self induced. Landed in Spokane to clear customs and get fuel, noticed an oil leak, got distracted, cleaned the oil, added more, somewhere in there told fueller "full". Didn't realise fuelled had never fuelled a twin cessna. Blew a tank at FL 180 in cruise, realised aux's didn't get fuelled. Holy cow, that gave the arteries a good cleaning! Still had gas to reach Chico Cali., so no big deal, but sure could have been worse if I missed and had to go to alternate.
Much more careful now...
ninjacrumb
Boeing Driver
4500 hours. 5 engine failures. 2 self induced in a navajo (both engines at the same time), blew out both the outboard tanks at the same time. That made my heart stop. Another was a catastrophic failure in a navajo. Again another in the navajo (blew the oil filter seal). And one on a King Air, lost the high pressure fuel pump. This all happened in my first 2500 hours.
Cheers!
Cheers!
- Cat Driver
Well one night in Inuvik I was really drunk and humping a local beauty when I fell asleep and sort of crashed, at least I did not finish the journey...
does that count?
does that count?
- cloudrunner
Technically speaking Cat, that is a "dead stick" landing so...yes, I believe it counts.Cat Driver wrote:Well one night in Inuvik I was really drunk and humping a local beauty when I fell asleep and sort of crashed, at least I did not finish the journey...
does that count?
ahhh then you have the no blow(ing cylinder)job so now, I'm not sure cat
I once met a very nice guy in his late 60's/early 70's who was driving cab between LG2 and the airport. May be some of you did as well.
He told us that he lost his medical after having flying DC-3, DC-4, DC-6, constellation, canso, CL-215...
The 15 minutes ride with him to get to the airport was pretty nice and full of cute anecdotes. He ended up his speach giving us our luggages and saying something like this with a little smile:
"You know, I flew 14000hrs in all sort of radials engines, never add an accident, an incident, even a single engine failure.....I which you the same"
I took his which and so far, so good
His speach looked pretty accurate and modeste at the same time. He was only answering our questions. I would never think he collected differents stories told by pilots he brings at the airport, to make them his own.
- Siddley Hawker
- Cat Driver
Spaceship 2
- Rank Moderator
2600 hours. 2400 in PT6 turbines
2 precautionary shutdowns...
1. in a twin otter due to low oil pressure ( VMC non-event )
2. reversed command of the power lever in a BE20. It was WACKED, pull the lever back and tourque, ITT, and Ng go up. We figured we'd never be able to shed enough airspeed to land and stay on the ground so we shut it down. Unfortunatly after the uneventfull landing we were well below Vmcg and got stuck on the runway after a couple humerous 360's and we realized we aren't going anywhere...to this day I am always suspicious when anyone claims they can taxi a BE20 single engine!!!!
Turned out to be this cheesey plastic cover (secured by a single wingnut) that covers the wires coming outta the generator. The cover had fallen and wedged itself between the linkages to the FCU, prop gov. and whatever else is running lengthwise along the PT6. The engineer that was flown down to rescue/repair us said he had never seen anything like it before.
It was a one minute fix! The kind that makes you wish you had popped the cowling the next day in the light and had a more detailed look around. No shit we were stunned. He pops the cowling, looks, scowls, removes plastic cover, closes cowling.....ok fire it up and try it out. Yup good to go.
