looking for specs (BE20, B1900C)
4930s
Post by 4930s »
Hi all,
I am looking for someone who can help with a few specs on the B1900C and the BE20.
Engines?
Fuel Burn?
TAS for flight planing?
OEW (cargo)?
Fuel Capacity?
Does the king air 200 have a cargo door or just an airstair, or is there a mod for such a thing?
ScudRunner
Re: looking for specs (BE20, B1900C)
Post by ScudRunner »
Google can help you with most of those questions , the 200 does have a mod for a cargo door
http://www.butlernational.com/king_combo.htm
Scuba_Steve
Post by Scuba_Steve »
Engines - 200 - PT6-41 1900c PT6-60
Fuel Burn - 200 - 800lbs first hour 600 lbs 2nd hour - 1900c 1000lbs 1st - 800lbs 2nd
TAS - Varies depending on engines, airframe etc but typically around 245 - 255 for both (in my experience - I once flew a 200 that would easily do 270)
OEW - 200 - could likely get down to 7500lbs with no seats and no auto pilot etc - 1900c 9500lbs (ish)
FUEL - 200 - 3600 - 1900C 4400
There is a cargo door mod out there for the 200, i don't know if it was factory installed or installed afterwards. Its rare to see though.
I haven't flown the 200 for awhile and most of my time is on a 'D' model 1900 so my numbers could be abit off but I think they are pretty close.
it'sme
Post by it'sme »
Engines on the B200 are -42's and a typical TAS would be 280kts. Have seen 290kts on a number of occasions.
There is a mod for a cargo door but they also came from the factory as 200C's. They carry a "BL" serial number and there were 141 that went out the factory door between 1979 and 2006. There are examples on the resale market cuurently such as http://www.controller.com/listings/airc ... 133438.htm
the cargo door did come from Beech. It's called the B200C. Tindi has one. Makes loading fat bastard on a stretcher a little easier but you have a lower max diff on cabin pressure.
raven54
Post by raven54 »
Always liked the "hatch back," ATL's also had the -42's.
Post by ahramin »
200s empty can be as light as 7500 pounds will all the stuff removed or as heavy as 8500 pounds for a B200 with modern avionics.
4930s
Post by 4930s »
so a striped out BE20 for cargo only and no Auto man 7500lbs - 8000lbs?????? Is this a good # to work with? and 260 KTAS, is this a safe flight planning speed? fuel burn 750 lbs/hr????
liveagain
Post by liveagain »
BE20
WEIGHT AND BALANCE
RAMP : 12590 Lbs
MTOW : 12500 Lbs
MZFW : 10400 Lbs
MLW : 12500 Lbs
Max AFT bgge : 410 Lbs (550Lbs NBB)
Max in ea. POD : 250 Lbs (Total : 500Lbs)
C.G Range : 12500 Lbs = 185.0 to 196.4
11279 Lbs = 181.0 to 196.4
Vso : 80 Kt
Vmcg : 85 Kt
Vmca : 91 Kt
Vr and V1 : 94 Kt
Vs : 102 Kt
Vx : 103 Kt
Vsse : 108 Kt
Vyse : 122 Kt
Vy : 126 Kt
Vfe 100% : 144 Kt
Vlo : 164 Kt
Va and Vle : 182 Kt
Vfe 40% : 200 Kt
Vmo and Mmo : 260 Kt & 0.52 M
Max. Glide : 135 Kt
Crosswind : 25 Kt
FUEL QUANTITY IN TANKS
MAIN : 2586 Lbs/ 1467 lt/ 386 USG/ 322 IMPg
AUX : 1059 Lbs/ 600 lt/ 158 USG/ 132 IMPg
TOTAL : 3645 Lbs/ 2067 lt/ 544 USG/ 453 IMPg
FUEL PLANNING
FIRST HOUR :700 LBS/395 LT/
SUBSQ. HOURS :650 LBS/370 LT
RES 45min :525 LBS/300 LT
APPCH :120 LBS/70 LT
TAXI :90 LBS/51 LT
Salute !
A good attitude
liveagain
Post by liveagain »
EMPTY WEIGHT from 7802 lbs to 8124 lbs...or more.
7802 lbs has a POD. Executive configuration is heavier.
A good attitude
Brantford Beech Boy
Post by Brantford Beech Boy »
If you are running straight freight, don't use a 200. Go with the 1900.
You will lose at least 1/3 of cabin volume in a 200 with having to leave space for the crew to get from the door to the cockpit and back. (unless yer doin bag runs with less than 1000lbs payload and have a pod). The Hunny has the airstair door up front just aft of the cockpit, so you can stuff her to the gunnels.
There are two types of 1900 in the current freight market (GGN had the only 1900D freighter I've ever seen and it wasn't airworthy last time I saw it..). The 1900B (serial number UB) has a much smaller fuel capacity of 2900 lbs but retains the same GTW as the 1900C (serial UC)
1900C will burn about 100lb/hour more than the 200 with about the same block time (especially ovey the shorter distances).
BBB
Scuba_Steve
Cariboo has two 1900C's up for sale if anyone is looking :)
