On the BC Coast
"first Round...to be completed before the end of the fiscal year" (Kevin Carrigan)
Trial Island
Entrance Island
Cape Mudge
Dryad Pt
"second round"
Green Island
Addenbroke
Carmanah
Pachena Pt
Chrome Island
All light stations are on the block.
Now, I may be no expert but:
TSB Safety Study of VFR Flight into Adverse Weather
SATOPs: WeatherThe Department of Transport locate automated weather measuring devices in support of VFR operations in the areas of highest risk in mountainous terrain.
TSB-A90-87
<snip>
The Department of Transport examine the policy for the contracting of manned weather observation services with a view to expanding the service in remote locations of highest risk.
TSB-A90-88
<snip>
The Department of Transport promote the upgrading of weather briefing facilities where required, for remotely-located commercial operations, and encourage commercial operators to provide crews with the means of obtaining a weather briefing for all flights.
TSB-A90-89
<snip>
The Department of Transport publicize the availability of Transcribed Weather Services at remote locations.
TSB-A90-90
Shouldn't the air industry be objecting to the unmanning of the lighthouses? What has been done to replace this valuable weather service? IIRC, here in BC many air ops still depend on those lightkeepers for true, up to date en route weather information that is not otherwise available ... I can only "assume" it is the same on the east coast.The closing of lighthouse stations by the Canadian Coast Guard has reduced the weather information available to pilots flying on the west coast of British Columbia. Lighthouse keepers aren’t accredited aviation weather observers, but the information they provide is essential for west coast VFR pilots since it is the only local weather information available. The Pacific coast is a unique operating environment where the weather conditions change quickly and vary dramatically over short distances due to localized weather phenomena.
Aviation weather reporting was thought to be inadequate even prior to the decommissioning of lighthouses. Weather information is perceived to be geared to IFR aircraft and not appropriate for VFR operations since the information is often not valid within a few miles of the reporting source. VFR pilots on the west coast need to know weather conditions at and below 1000 feet ASL.
Comments were received that weather information from the lighthouse stations, which was issued every three hours, was ignored if it was more than one hour old since pilots are looking for more current observations. Other comments indicated that not all lighthouses were required, only specific ones that are located in areas where there is significant variable weather activity or at other strategic locations.
Marine and aviation weather services appear to be isolated. Better and additional services could be realized if these were amalgamated. Weather information from ships, tugboats, fishing boats and lighthouses should be made available to pilots. Most aircraft are equipped with FM radios and can communicate with fishing boats and other ships.
The operating conditions on the west coast require VFR pilots to push into, through or above fog and cloud. The Task Force was told that if pilots don't operate in these conditions, the companies can't survive because these are typical coastal weather conditions. It has become an acceptable (to industry), though illegal, way of operating. Providing pilots with better weather reporting will enhance their decision making as far as choosing a route to fly or areas to avoid, but it will not stop them from continuing to fly into deteriorating weather conditions. It is important to note that in recent weather-related accidents that have occurred on the west coast and elsewhere, the pilots were flying in weather conditions less than the minimum allowed by regulation.
The British Columbia Air Operators Group is a subcommittee of the British Columbia Aviation Council. NAV CANADA has been involved in discussions with this group in an attempt to resolve the weather service issue, by determining user requirements and meeting those demands. Transport Canada should ascertain the progress of solutions to this problem and determine what effect the loss of weather reporting services has had and will have on aviation safety.
SR 69 - Recommend Transport Canada consult with the British Columbia Air Operators Group and NAV CANADA to determine what is being done to improve the weather reporting services on the west coast of British Columbia. A safety review of the issues would be justified if there is no obvious and timely solution to these problems.
OPEN LETTER TO CANADIAN CITIZENS FROM LIGHTHOUSE KEEPERS
Once again, government bureaucrats are attempting to remove the services of Lightkeepers from the Canadian people. They are working quickly to implement a plan to de-staff the remaining 27staffed lightstations on the west coast and the remaining 9 on the shores of Newfoundland and Labrador.
The Assistant Commissioner of Coast Guard, by continuing to refer to these stations as ‘automated’, is attempting to lead the public to believe that the stations being de-staffed are automated already and that it is only a matter of removing the Lightkeepers. Nothing could be further from the truth.
Lightkeepers have been key players in public safety for over a century and their efforts continue to be held in high regard by the Marine and Aviation communities on both coasts. This is not romanticism. It reflects reality. The services that the Keepers perform are professional and extensive and there simply is no reliable way, even in this day, to replace them with automated equipment.
Their weather observations have a positive impact in both the prevention of incidents and the success of rescue efforts when incidents occur. They help in the accuracy of forecasting and assist the timely flow of goods and passengers along the waterways of both coasts. There have been numerous attempts to duplicate these observations by a variety of equipment and all have fallen miserably short.
Lightkeepers continue to assist in Search and Rescue, provide sanctuary, act as first aid outposts, relay warnings and distress calls, liaise with RCMP, Fisheries, Pollution Control and other government agencies, and we help to ensure Canada’s sovereignty and security by establishing a strong federal presence on our coastlines. Our work is not limited to this list. We protect and maintain these, your public assets, the gems of your coasts, the Lighthouses.
Our concern is not for our jobs. It is for the continuation of the service that Canadians want, expect, and deserve to have.
Call and write your representatives.
Respectfully,
Steve Bergh – President BC Lightkeepers Local 20232 PSAC
Alice Woods – Vice President
Chatham Pt Lt Stn
Box 187 Campbell River, BC
V9W 5A7
250 203 2421
newdawn@lincsat.com
