For the descent, do you guys calculate your own T/D or do you just let the FMC/FMGS take care of it and follow the profile it publishes? What if ATC takes you off of the STAR and you have now had significant reduction in track miles. You will end up high, right? Sure you put up spoilers and yati yati yata to get down quick. But is there anyway to anticipate this? How hard will your CP crack down on you if you end up being too LOW because of ATC's vectors and you end up using Thrust for an extra 20 miles in straight and level?
So how do you well-plan a descent taking into consideration all the distractions that can be applied to it?
In the FMC/FMGS, back at the departure gate, do you put in the entire route INCLUDING the star? Or do you put in the STAR when closer to the T/D? If so ? How many miles away from T/D do you put the star in.
How do you know which Arrival Runway to put in the FMC if you're 250 miles out? I assume you can't pick up the ATIS when so far out? Because won't the arrival runway COMPLETELY change your T/D position?
Imagine 26L and 08R at YVR. Coming in from Northeast, you will have an extra 30 track miles for 08R. I assume you would start your descent later, or at least, AFTER VITEV's -FL210 restriction, you would maintain a shallower descent profile?
If somebody could answer those, that would be great ! I've always wondered
