3 degree slope
greenwich
3 degree slope
Post by greenwich »
...what's that 3 degree slope calculation "rule of thumb" again???
Thx
G
Arthur Q
Post by Arthur Q »
I think this is it, but don't quote me...
Take your rate of descent eg. 700fpm double the 7x2=14 add 0 to it
Gives you 700fpm at 140 kts should give you 3 degrees slope.
With that said I could be wrong it's been a while since I had to think.
:smt017
Either you're in, or you're in the way
backon3
Post by backon3 »
(Groundspeed divided by two) times ten = fpm (to maintain 3 deg)
CAWI
Post by CAWI »
easy way...half of your groundspeed.....add a zero.
Check this out......Very handy
http://www.flightinfo.com/rulesofthumb.asp
greenwich
Post by greenwich »
Thanks crew... (1/2 gnd speed add a zero!)
Also, what was the one that went something like....
"1,000' AGL three miles back, 2,000' AGL six miles back", etc., etc????????
G
C-150Pilot
Post by C-150Pilot »
HAHA I like this one
#10 - Correct time to Lower Gear
Preferably before coming into contact with the runway surface.
Fly it until the last piece stops moving
"I give your landing a 9...on the Richter scale."
greenwich
Post by greenwich »
WTF???
gowest
Post by gowest »
1 nm= 300agl, 2 nm out=600 agl and so on...
Panama Jack
Post by Panama Jack »
TLAR= That looks about right!
-President Ronald Reagan
Cap'n P8
Post by Cap'n P8 »
I have two. First using groundspeed, almost the same as a previous post. Take half the groundspeed, put a zero on the end...and add 30.
Eg. 120 kts g/s = 60 = 600 = 630'/min
Second calculates height at a certain distance. Take the distance back, multiply by 300 (multiply by 3 and add two zeros) and add the surface elevation.
Eg. 5nm x 3 + 00 = 1500 + height ASL of surface = Target altitude for distance back
CAWI
Post by CAWI »
Why add 30'. Just curious.
Panama Jack
upontop325 wrote:I have two. First using groundspeed, almost the same as a previous post. Take half the groundspeed, put a zero on the end...and add 30.
Wow, I have trouble just keeping my VSI within 100 fpm of target!
Cap'n P8
Post by Cap'n P8 »
Why add thirty? Beats the hell out of me...just what I was told that's all. But hey it's only meant to get you in the ballpark anyways. I actually just learned that one a month ago when I went stateside to do my ATP checkride on my FAA ticket.
helmetfire
Post by helmetfire »
Or simply:
tan of 3 deg x distance from rwy in ft= your target altitude agl'
eg.
tan 3deg* 6080'=318' agl
Make sure you have your calculator handy as you're hand bombing the approach.
