727 overrun in Moncton
CD
Re: 727 overrun in Moncton
Post by CD »
Where's Joe Patroni when you need him?
Okay. But you keep those dinky toys out of my hair and away from this plane for 15 minutes, maybe less. I'll DRIVE it out.
Agrios Anemos
Post by Agrios Anemos »
Hello all,
No one was hurt, that's the main part and i was always told, a good landing is one you walk out off.
Good work
cheers
billy ray valintine
Post by billy ray valintine »
it's not uncommon for the speed brakes to sink back down once hyd. are off,but looks like the
l.e. flaps and slats are up,t.e. as well. is this normal?
:oops:
pez
Post by pez »
Agrios Anemos - For the choice of runway, I'm not really qualified to comment on this or second guess the crew, but I should mention that the crosswind really wasn't as you stated. Both rwys available had crosswinds reported at the time, 06 30 deg right, 11, 20 deg left (var 20 deg W). 06 has an ILS and 11 has NDB and RNAV approaches only. Seems that neither rwy would have been limiting in those conditions (my speculation only), and 06 had an ILS.
Colin
billy ray valintine wrote:it's not uncommon for the speed brakes to sink back down once hyd. are off,but looks like the
:oops:
No, it's not. Usually the Kruger flaps will droop with hydraulics off as well...
c170b53
Post by c170b53 »
Just guessing, hard to tell the conditions from 800 ft away :D The air bags can, lift the aircraft when access to the jacking pads are not available, they spread the load over a larger area if the soil does not allow a load concentration and of course they can begin lifting when only a small space under the desired lifting point is available. They are limited in that the lift surface must be relatively parallel to the ground on which the air bags are placed. The steel plates keep the mains from sinking if the soil won't support the MLG load. Possibly the RH MLG has folded or sunk. And Bushav8er I've also had the joy to have been behind a shovel to dig out big stuff as well.
hairdo
Post by hairdo »
They got it out today, sitting on the apron now. They trucked in an awful lot of gravel though. Don't believe they used airbags to get it out, just dug out around it, put the gravel down, put some steel plates in, and towed it out. From my understanding, the gear didn't collapse, it's just muddy off the end and they sunk in.
Gravity lands us, we just make it look good.
Agrios Anemos
Here is the weather for the time this occured.
CYQM 240700Z 07017KT 15SM -RA BKN006 BKN008 OVC013 02/01 A2947 RERA RMK SF5SF2SC1 PRESFR SLP982
CYQM 240600Z 07008G17KT 4SM +RA BR BKN006 OVC009 02/01 A2954 RMK SF6SF2 /R17/ SLP008
CYQM 240500Z 06015G25KT 5SM -RA BR BKN006 OVC010 01/01 A2956 RERA RMK SF6SF2 PRESFR SLP015
CYQM 240400Z 07020KT 7SM RA FEW003 BKN005 OVC007 01/01 A2963 RMK SF2SF5SF2 SLP036
CYQM 240338Z 08015G20KT 8SM RA FEW003 BKN005 OVC007 01/ RMK SF2SF4SF2
WASIE
Post by WASIE »
hairdo wrote:They got it out today, sitting on the apron now. They trucked in an awful lot of gravel though. Don't believe they used airbags to get it out, just dug out around it, put the gravel down, put some steel plates in, and towed it out. From my understanding, the gear didn't collapse, it's just muddy off the end and they sunk in.
Hairdo you seem to be well informed.
pez
Post by pez »
Taxied past it yesterday, sitting on the apron plugged into a ground power cart with maintenance folks and trucks all around it. Sitting level on its gear, right wing and all its bits certainly looked intact from what I saw. I think it may have been doing engine runs later yesterday afternoon.... Certainly sounded like it!
KAG
Post by KAG »
It's a Boeing, it's fine.
Chase lifestyle not metal.
ScudRunner
Post by ScudRunner »
KAG wrote:It's a Boeing, it's fine.
If it Ain't Boeing I Ain't going!
Boeing Build's Airplanes Douglas Builds Character!................................
:wink:
polar one
Post by polar one »
Be sure to include that belief in the cover letter with your resumes. There might just be some companies out there that expect just a bit more from a good landing. No point in surprising them with a bent plane from one of your good landings.
99% of pilots give the rest a bad name
What we learn from history is that we fail to learn from history
Braun
Post by Braun »
The 727 flew back to CYHM last night. Gear down the whole way. Hehe.
767AAY
Post by 767AAY »
Did a gear swing over the weekend, made some minor repairs and she's back in service as of yesterday!
Great job by all involved!
