arctic navigator wrote:This now puts you 300 ft beyond the end of the runway and into the weeds.
Who cares if you go off the end, that's what insurance is for. A little bent metal and a bruised ego is way easier to deal with than a fireball. Your passengers, and likely yourself as well, will walk away with nothing worse than some cuts and bruises if you go off the end at 50-60kts slowing down. What's the outcome going to be if you take it to the air, if you even can get there? If all goes well the aircraft won't have a scratch other than the damage from the blowout, but that's one big if...
This was my point. If you read all my posts.
I'm simply trying to highlight what V1 actually is. There are many people out there that think "if I reject a take-off before V1 I will get it stopped." This is not the case. If you reject a take-off due to an engine failure the numbers say you should be able to stop it. If it is for ANY other reason there is no guarantee. You may not get it stopped. Especially if you are heavy and near the limit of the runway. A tire failure is a situation that will seriously degrade stopping distance and directional control. Expect more blown tires, and possibly a fire, leaking fuel etc.
But I agree going off the runway at a slow speed is better than having a catastrophic failure in flight.
Here is what Airbus Says
http://www.airbus.com/store/mm_reposito ... -SEQ04.pdf
Tire burst in the V1 minus 20 kt to V1 range: Unless debris from the tires have caused serious engine malfunctions, it is far better to get airborne, reduce the fuel load, or proceed for an overweight landing, and land with a full runway length available
http://www.bluecoat.org/reports/TOSTA-appendix-4.pdf
It won't let me cut and paste from the PDF, but at the bottom of Page 6 from this last link it gives an example of a Convair 990 that rejected prior to V1 with a tire failure, that overran the runway.
The report also states that between 1964 through 1976 171 RTOs that caused damage or death occurred and of those 149 involved wheels, tires, and brakes, of which 124 were a direct result of tire failure. Some were initiated before V1, some at, and some after V1.
Excellent report from the link above.
BTD
