For your 1st and last point, see CAR 602.127 (1)Ref Plus 10 wrote: Do you have a CARs reference for this? So long as you're above the sector altitudes, it really doesn't matter where you go. It is in fact completely legal, though probably ill-advised, seeing as you will be much higher going direct to the waypoint, then descending to minimums, than doing the full approach, where you will be allowed to descend to procedure turn altitude on the outbound leg.
So far as I can tell, the only things you need to conduct a straight in approach are a means of ascertaining wind direction and confirmation that the runway is clear
Agreed, however, again I refer you to sector altitudes. You could do your procedure turn at 17 miles if you wish, so long as you are at your 25 mile safe altitude. Which would defeat the purpose in most cases.
Ref
In that case, the approach procedure does not allow for a straight in approach. You can argue that you can do the "procedure turn" any way you want, as long as you stay within the protected airspace, however you do that on a ride and I can guarantee you that you will fail that item.Unless otherwise authorized by the appropriate air traffic control unit, the pilot-in-command of an IFR aircraft shall, when conducting an approach to an aerodrome or a runway, ensure that the approach is made in accordance with the instrument approach procedure.
For your second point, see post above.
