Hello all,
I understand how to use the following formula (in the three variations -> removal of weight, addition of weight and shift in position of weight) but I am trying to figure out how 'they' derived it to begin with:
w/W = d/D
It must be a simple process of cross-multiplying but I have been quite unsuccessful as of yet.
If anyone has a link or a decent explanation, that would be greatly appreciated. Further elaboration on how to use the formula can be provided if requested.
TD
Weight Shift Formula
Re: Weight Shift Formula
I think it's weight to be moved/aircraft weight=distance to move cg/ac arm. Math is easy from there- good luck.
I couldn't make the equations post all that well so I attached a file with the derivation.
Weight Shift Equation.pdf
- (92.33 KiB) Downloaded 770 times
Excellent, much appreciated. I did not think to take that approach.Aeros wrote:I couldn't make the equations post all that well so I attached a file with the derivation.
The use of the formulas are quite simple, but deriving them quite a bit tougher (for me anyways!). I derived the other two variations as well, on paper. I'll post those tommorow when I clean it up a bit for any other curius people with nothing better to do with their time
Cheers.
