* AvCanada's Home Page * Photo Gallery * Directory * Topsites *Weather *Enter Chat * Media Kit
It is currently Wed May 22, 2013 9:02 am
Who is chatting
Who is chatting
Enter Chat
Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: IO550
PostPosted: Sun Aug 01, 2010 10:53 pm
Offline
Hi Guys,
we have to ferry a 206 with a 550 engine installed. Could you give some advice... how to handle this nice engine properly?
Thanx!
C185
Top
 Profile
 Post subject: Re: IO550
PostPosted: Mon Aug 02, 2010 1:05 am
Offline
Don't cruise with RPM below 2300. Continental has a Service Bulletin on this and it is related to the crankshaft counterweights. As with all counterweighted engines (every Continental six cylinder) you should make RPM changes slowly and smoothly and avoid surging the engine.
http://www.tcmlink.com/pdf2/CSB09-11.pdf
Keep EGT 100F ROP. I guy I knew had two 206s with 550s and was going through jugs like crazy at 50 ROP. Never go LOP regardless of what kind of fancy engine analyzer you have or fuel savings you crave.
Stage cool as always.
Not a big fan of the 550. I always thought of it as a heavyweight boxer with a glass jaw. 520 all the way...
Top
 Profile
PostPosted: Mon Aug 02, 2010 4:13 am
Offline
Really pro 550 in the 185. Never compared the same 185 with the 520 & 550 off the same strip but two different 185's.. one with the 520 & one with the 550 and there was no comparison. Could have been the plane, could have been the engine. Who knows other than the right plane with that 550 will perform.
Top
 Profile
PostPosted: Mon Aug 02, 2010 5:05 pm
Offline
I run mine at 24 square and 16 gallons per hour,900 hours and no cylinder trouble.It was the best mod that I put on my 185. :mrgreen:
Top
 Profile
PostPosted: Tue Aug 03, 2010 12:03 pm
Offline
PRO 550 :-)
Thanks for the advice...
Here some numbers (206F on EDO floats + Flint wingtips):
25/25 @21GPH -> 135kts IAS
22/24 @15GPH -> 122kts IAS
:prayer:
Top
 Profile
PostPosted: Sat Sep 04, 2010 7:44 pm
Offline
Really good engine the 550, I have one in a C185 and no comparaison with a 520.
As for running 100 rop ??
I run mine LOP on wheels and skis, on floats I may have to run 50 rop to keep CHT cooler depending of temperature.
Top
 Profile
PostPosted: Sun Sep 05, 2010 1:22 am
Offline
Not the LOP/ROP debate again. :cry:
Top
 Profile
PostPosted: Sun Sep 05, 2010 4:57 pm
Offline
No brainer, LOP is cooler so easier on the cyl and engine.
Top
 Profile
PostPosted: Sun Sep 05, 2010 7:14 pm
Offline
They like to vapor lock at hot DA locations. I went to get fuel and had fumble with the thing for a while before we were going again. I found if you dont want to start the engine with full rich in DA conditions. if you get vapor lock, just full throttle, ICO and crank for a while, if that doesnt work go get a drink and come back!
Top
 Profile
PostPosted: Mon Sep 06, 2010 4:25 am
Offline
I thought ROP of peak would be cooler? More fuel being added to aid in cooling?
Top
 Profile
PostPosted: Tue Sep 07, 2010 3:34 am
Offline
Ugh.
Why do you take off with the mix full rich?
When your engine is over-heating, do you lean the mix, or go rich? [among other things]
Also think of the poor exhaust valves, getting the blasted by the heat. Running 50-100 degrees hotter than they otherwise would.
I know, different engine but the theory is the same.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 6 guests
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
webmaster@avcanada.ca
AvCanada Topsites List
While the administrators and moderators of this  forum will attempt to remove or edit any generally objectionable material as  quickly as possible, it is impossible to review every message. If you feel a  topic or post is inappropriate email us at support@avcanada.ca .  By reading these forums you acknowledge that  all posts made to these forums express the views and opinions of the author and  not the administrators, moderators or webmaster (except for posts by these  people) and hence will not be held liable. This website is not responsible or liable in any way for any false or misleading messages or job ads placed at our site.
  When you post a message, your IP is logged and may be provided to concerned parties where unethical or illegal  behavior is apparent. All rights reserved.
