Brick Head wrote:Raymond Hall wrote:
The irony here is not that you are using the charter in an attempt to change the laws regarding mandatory retirement at the federal level. The irony is that you are attempting to use the charter to take from one age group, and give to another age group, on the basis that to not do so, is ageism.![]()
" You do not have a human right to take that which does not belong to you, just because you fit a specific age group. Making sure the collective pie is distributed as intended has nothing to do with ageism. "
" At the end of the day the charter is about equality. Not about using it as a means to over ride the intended distribution of the collective bargaining process."
"Without it, unions can not control distribution because people won't fulfill their duty to their peers if not forced to. "
REPEAT
"Without it, unions can not control distribution because people won't fulfill their duty to their peers if not forced to."
And sir. That is what we intend to do.
Give it a rest Brickhead. Your responses are starting to sound like your name.
