The Annie is alot more tame then the Beech 18. Yes, British systems can be a little "wierd" to us North American folk. I fly a Chipmunk that has its own type of brake system(I posted earlier on this) so I will not do it now to save space. The brake system is the same as most Tiger Moths.Cat Driver wrote:Quote:
Weird would be the Anson Mk. five.The Anson was a very nice flying airplane except for the brake system.
This sounds like the begining of a good story.
The English sometimes build things that are truly demonic, such as their baggage carts that they supply at the airports that have full castoring wheels on all four corners, the things will go every direction except the one you want it to go.
The Anson had vacuum over hydraulic brakes that were downright frightening if you were not aware of the lag from the time you applied the brake/'s until they actually started to engage because if you increased pressure thinking nothing was happening they locked up the wheel/'s and it got exciting very fast.
It was actually easier to fly than the Beech 18.......except for the brakes.....
What you need to keep in mind about the Anson is the fact that this was the first retractable landing gear system ever made by Avro. I have heard about people talk about the braking system.
The Manchester and later on the Lancaster used a pneumatic braking system as well.
