Typhoon wrote:Great, thanks for all of the comments. Would anyone happen to know of anywhere in Africa/Asia that hires low time pilots? Flying in that sort of environment has always interested me.
Personally, until you know the lay of the land, I highly recommend working in Africa with a Canadian company. This way you know that the operation is relatively safe compared to what's out there. Not saying all companies based in Africa are bad and scary, just saying there are lots of both good and bad, and the bad can be pretty terrifying. However, lucky for you there are plenty of safe Canadian operators in Africa.
Here is a thread in the Specialty Air Services forum regarding some humanitarian type flying with Canadian operators:
viewtopic.php?f=25&t=68955
There are also VFR operators such as Sander Geophysics and Fugro Airborne Surveys.
Flying in Africa can appear to be a difficult part of the industry to break into while sitting here in Canada, but once you get over there, you meet lots of people easily and it's not hard to network. But if you can get on with one of the above mentioned companies in Canada, you'll get a good look at what your options are over there.
